Engine weak above 4000 rpm
  • jcleritz
  • jcleritz's Avatar Topic Author
02 Sep 2014 15:48
#645991
I have a 79 KZ 400 Ltd. I just cleaned the carbs and I think I did a good job since it starts perfectly and pulls better than ever at low rpms. However over about 4000 rpm it won't pull, seems like it is not getting fuel. This happens in every gear, with or without the air filter in place.
I adjusted the timing but it makes no difference. Did I do something wrong when cleaning the carbs? Is the float bowl level too low? Is it a valve adjustment issue?
Thanks for your help.
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Re: Engine weak above 4000 rpm
02 Sep 2014 15:53
#645992
Check for kinks in your fuel line. I had a similar issue, @ about 6k on a KZ650. Had a longer a fuel line... snipped ~1/2" and all is good...
Also, got an inline fuel filter? If so, new or used? It's only $2-3 for a new one... please consider this.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • jcleritz
02 Sep 2014 15:55
#645993
What a good idea, I will check tonight for kinks. J
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
02 Sep 2014 15:56
#645994
10-4... good luck. Also consider the filter...
C.
  • jcleritz
03 Sep 2014 12:12
#646121
Well I checked the fuel line, it is clear. What next? Maybe the petcock is bad? Would cleaning the carbs affect the float bowl levels? Thanks.
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
04 Sep 2014 06:29
#646216
these old carbureted girls' fuel is gravity fed....Make sure your tank is venting properly...I had a TON of crud inside my gas cap's vent channels...They "breathe" through the keyhole in the cap...Not enough air in, not enough fuel out! Something to try, anyhoo!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • jcleritz
04 Sep 2014 12:23
#646250
Thanks I will try that next.
  • steell
  • steell's Avatar
04 Sep 2014 20:33
#646298
Check your timing advance and make sure the cam lobe rotates counter clockwise easily, and snaps back into position clockwise. If the timing is not fully advanced at 3500 rpm, the motor will fall on it's face.
  • jcleritz
05 Sep 2014 07:26
#646335
Thanks for the suggestion, the timing advance is well-lubed and moves easily. J
