KZ650 Starter Clutch
  • murquiza
  • murquiza's Avatar Topic Author
28 Aug 2014 20:54 - 28 Aug 2014 21:39
#645544
I'm doing my starter clutch, I'm following the procedure described in the PDF that is circulating around.
The instructions are clear. Removing the lick plate staked screws and the secondary shaft back plate ones has been a pain, even with JIS bits and an Impact wrench I managed to strip the heads of three.
Ungluing the gaskets is another dauntless task, those gaskets are glued and are really stubborn to remove.
Other than that it can be done with the engine on, there's plenty of space to work.
I noticed that the springs were notoriously shorter than the replacement ones. I hope this fixes the problem. Everything else looks fine so far.
This is how the older (on top) springs look compared to the new ones.
Attachment ImageUploadedByTapatalk1409284174.152109.jpg not found
One thing Idk is if I should use some blue loctite on the starer clutch allen bolts. When I removed them there was some kind of thread locker on them.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
Last edit: 28 Aug 2014 21:39 by murquiza.
  • baldy110
  • baldy110's Avatar
Re: KZ650 Starter Clutch
29 Aug 2014 07:59
#645575
Are you just replacing the springs? There is a roller and spring kit out there.
  • murquiza
Re: Re:KZ650 Starter Clutch
29 Aug 2014 20:01
#645642
baldy110 wrote: Are you just replacing the springs? There is a roller and spring kit out there.
No, I replaced the springs and rollers, got them from Z1enterprises. I nust finished but I'm afraid that t didn't fix it, it improved but still slips.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
30 Aug 2014 05:50
#645662
Did you check the starter gear while you had it apart? A worn starter gear will cause problems. Ed
  • Strongchain
  • Strongchain's Avatar
30 Aug 2014 07:39
#645668
I would use loctite 648 on internal bolts. And loctite 272 for a rotor nut if it was mine.
  • murquiza
30 Aug 2014 08:26
#645673
650ed wrote: Did you check the starter gear while you had it apart? A worn starter gear will cause problems. Ed
Ed,
It has to be that, the gear was shiny but didn't look worn and I didn't feel anything on the surface.
I guess I will have to do all over again :(. I will buy the new gear.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
  • murquiza
30 Nov 2014 12:16
#654971
I'm extremely frustrated. Yesterday I took the bike apart and replaced the gear, put it back together and I have the same issue, the starter slips.
So far I have done:
- Replace the clutch springs and parts with a repair kit from Z1enterprises
- Replaced the starter gear with a new OEM one
With the new gear I can see a slight improvement but still the starter slips when it has to engage. If the bike is at operating temperature I can starter with the electric starter, otherwise I have to kick start it.
I need advise on what could be the issue. It's is extremely frustrating being so close to have it how I want it and have this issue that I can't fix.
Should I replace the complete secondary shaft assembly?
HELP!
Ont the positive side I mastered the process of replacing the starter clutch with the bike on the center stand and the engine i the bike.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
  • tinlizzie37
  • tinlizzie37's Avatar
30 Nov 2014 13:55
#654982
It would be best to remove the anti-friction oil or additives you have in the bike. I've been using Wal-mart oil for 10 years and haven't had any problems.
Bob KZ 650 E1, En 450
  • baldy110
  • baldy110's Avatar
30 Nov 2014 15:12
#654991
tinlizzie37 wrote: It would be best to remove the anti-friction oil or additives you have in the bike. I've been using Wal-mart oil for 10 years and haven't had any problems.
Really, that's your advise, I have never had or heard of a starter clutch acting up due to oil, it will effect the clutch but not metal to metal surface contact.
Sometimes I have had starter clutch repair kits that did not work. I end up taking two new kits and using a micrometer measure everything and pick out the best ones to use. That has worked for me in the past. I even replaced all the starter clutch components with new parts like you did and still have it not work right. On that incident I took the starter clutch gear, new and the used one and again using my micrometer I measured the surface where the roller ride on. I picked the gear which had the largest diameter, that happened to be the used one and it worked. It can be very frustrating due to the work involved, be patient.
The following user(s) said Thank You: murquiza
  • murquiza
30 Nov 2014 15:36 - 30 Nov 2014 15:45
#654993
Definitely is not the oil, I use Mobil 1 Racing 4T which doesn't have the anti friction modifiers than the ones used in cars. Tinlizzie, my problem is with the starter clutch, a completely different thing thing the engine clutch.
I guess I will have to keep trying. The measurement is a good option, I believe I still have somewhere the old parts. I will compare the sizes when I take everything apart once again, but when I do, I want to have a spare clutch assembly and I'm going to crank it with the engine open to see if it engages. :angry:
Thank you Badly, it's good to know that this happened to somebody else before.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
Last edit: 30 Nov 2014 15:45 by murquiza.
  • KZB2 650
  • KZB2 650's Avatar
30 Nov 2014 18:15
#655011
Where did you find the new starter gear ??
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • murquiza
30 Nov 2014 18:44
#655013
I got it new off eBay. Kawasaki part number 12046-1032
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
