250 CSR side panels
  • Newguy 250CSR
  • Newguy 250CSR's Avatar Topic Author
250 CSR side panels
24 Aug 2014 13:13
#645005
Ok, I'm new to the motorbiking world, and I just broke-off a new project: I inherited a '81 KZ250 CSR that needs some work. Just now getting into research to find parts, etc (not least among them was a set of keys!). One thing I haven't been able to readily find are a set of red side-panels. Or, specifically, just the right one (left one is on, and in good shape).
There is certainly more to come - carb cleaning, tank cleaning, new sprockets/chain, new signal lenses, seat, etc...but I'm dedicated to do as much as is reasonable myself. Case-in-point: when I got into biking, I self-taught myself through 2 full road-bike builds, 3 vintage full restorations, and countless bits of maintenance for friends. Now, it's time to start playing with motors...
  • pete greek1
  • pete greek1's Avatar
Re: 250 CSR side panels
24 Aug 2014 13:54
#645008
Newguy, go to the classified section, & post the parts your looking for in the WANTED section, & if someone has them they"ll let you know
& put a check in the box to be notified of any replies
Pete
The following user(s) said Thank You: Newguy 250CSR
  • Tyler
  • Tyler's Avatar
24 Aug 2014 20:09 - 24 Aug 2014 20:10
#645035
I used to have a 250 a while back, let me look around I may have a cover for you! I know for sure I have turn signal lights laying around in one of my parts boxes.
"74 Yamaha DT 400 Enduro
Last edit: 24 Aug 2014 20:10 by Tyler.
  • Newguy 250CSR
25 Aug 2014 05:23
#645051
That would be awesome! Also, I would be happy to take some lights off your hands - I recently moved from Minnesota to North Carolina, and we had to pack everything in the POD pretty tight - little bit of damage...
Also, if you find anything in your parts boxes, let me know how I can compensate you for shipping and parts (cash, local beer, bad advice, etc).
  • Newguy 250CSR
02 Sep 2014 07:23
#645897
@Tyler - any luck on your side?
  • Tyler
  • Tyler's Avatar
02 Sep 2014 08:04
#645905
I sent you a private message a while back, check your messages and get back to me.
