Missing Crankcase Bolt - Which one do I need??
  • krayneeum
  • krayneeum's Avatar Topic Author
20 Aug 2014 09:54
#644604
Hey all,
Just a quick question.
I'm missing a crankcase bolt and I can't seem to wrap my mind around which one I need.
Using this as a reference:
www.partzilla.com/parts/search/Kawasaki/...D+PATTERN/parts.html
Sorry for the silly request! >_<
Thanks!
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
Re: Missing Crankcase Bolt - Which one do I need??
20 Aug 2014 10:13
#644605
Uhhhh....yeah...that diagram made my head hurt....I CAN tell you that I just bought a couple from my local kaw dealer...should be an active part...or take one of the other ones to a fastenall store (If they are in your area) they probably will have them
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
20 Aug 2014 11:16 - 20 Aug 2014 11:18
#644611
Not a silly request at all. That diagram is the wrong one. The bolt you need is just like the one that is a few inches forward of it. Here's the diagram and below that is the table that shows previous part numbers. That may make it easier to find a replacement. The bolt in that table marked part number 130BA0670 is still available from Kawasaki. Ed
Attachment 00003_2014-08-20.jpg not found
Attachment 00003a_2014-08-20.jpg not found
Last edit: 20 Aug 2014 11:18 by 650ed.
The following user(s) said Thank You: PLUMMEN, krayneeum
  • krayneeum
20 Aug 2014 12:45
#644620
Ah, thank you Ed! Once again you prove to be a great help.
I knew something funny was up with that diagram! :silly:
