Clutch cable
- koloj
Clutch cable
19 Aug 2014 17:22
I'm just wondering is the little spring under the clutch cover only thing to return the clutch Handel to orignal position cause mine won't go back all the way if I tighten it up on top or in tge middle their is like no play in the clutch to engage and disengage clutch hints
Re: Clutch cable
19 Aug 2014 17:51
No. The springs in the clutch mechanism push things back when the lever is released. Have you tried properly adjusting the clutch using the instructions in the Kawasaki Service Manual? Ed
- koloj
Re: Re:Clutch cable
19 Aug 2014 18:09
No my manual just shows one spring the clutch mechanism moves freely with out the spring and cable
- koloj
Re: Re:Clutch cable
19 Aug 2014 18:43
U were right strange when I tighten down the case on side like boom worked crazy
