Question about a base gasket
  • Slade74
  • Slade74's Avatar Topic Author
18 Aug 2014 05:28
#644334
I have noticed that my base gasket is leaking just below the cam chain tensioner. I was looking closely at the base of the cylinder, and it looks like the current gasket is a light gray liquid type gasket(no paper gasket or otherwise).
Mine is a "81 KZ650 CSR
My question is, did these come with a liquid style base gasket from factory, or were they a fiber style gasket, and someone has had the cylinder off?
Thanks.
1981 KZ650 CSR
  • Tyler
  • Tyler's Avatar
Re: Question about a base gasket
18 Aug 2014 07:14
#644341
There should be a base gasket no sealant would have been used at the factory. you could try re-torque the head, but if there is no gasket you should take it apart and see what else the previous owner messed with...
"74 Yamaha DT 400 Enduro
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
18 Aug 2014 07:41
#644344
Definitely replace the tensioner seal, before tearing down the top-end of your motor.
I had the same issue, and thankfully it was just a bad tensioner o-ring. :pinch:
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: PLUMMEN
