I need a Lower left hand exhaust pipe (4 into 4)
  • Z1Driver
  • Z1Driver's Avatar Topic Author
  • love the smell of triple smoke
15 Aug 2014 20:54 - 15 Aug 2014 22:49
#644148
I'm looking for a lower left side 4 into 4 exhaust pipe for my Z1B. I know one can get complete repo exhaust pipe sets but all I need is the lower left pipe. The othert three are solid. Doesn't have to be showroom condition. Could even be for a 76 KZ.900. If some one knows where one of these pipes are hiding I sure would appreciate the info on it. I followed Seymores advice and put a post up in wanted too.
I am getting closer the refinishing my Z1 after it sat for over a year. If you remember I ended up with bent valves after letting my youngest daughters boyfriend ride it. Got the valves in put the head on. Cam chain was stuck down someplace. We had to pull the head to get the chain back up. note to self: hang on to wire on cam chain and don't loose it down inside.
Got the cam chain out, re-installed the head with another set of $60.00 in gaskets. When adjusting the valves I duscovered the new intake valves need thinner shims than I had on hand.....HMMM Don't the valves in general get tighter with use? Took the head back off and back to the machine shop. The Tech did a great job, he just forgot to check stem height. He ground the stems for no charge after I brought a FSM to him.
Head back on, another $60.00 in gaskets, valves all checked good. Put the motor back in the bike and stuck in new plugs. Installed the carbs and started on the exhaust. Ran into a problem with repaired pipe. But at least the motor has good compression using the kick starter to turn over slowly. :silly: .
One of these days the old gal will be back on the road. Tim
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: 15 Aug 2014 22:49 by Z1Driver.
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Re: I need a Lower left hand exhaust pipe (4 into 4)
15 Aug 2014 21:14 - 15 Aug 2014 21:15
#644150
Ummmmmmmmmm... MODs, think this belongs in the "WANTED" section.
Hey Z1D, here are a few CL options to contact. Someone may have what you're looking for.
Seattle...
seattle.craigslist.org/est/mpo/4607757098.html
In Spokane, but listing in Seattle...
seattle.craigslist.org/see/mpo/4586823711.html
Near me, can help... if needed
seattle.craigslist.org/oly/mcy/4617186946.html
In Spokane Valley...
spokane.craigslist.org/mcy/4532978760.html
Yea, saw where you are. Thanks for that in your profile...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 15 Aug 2014 21:15 by !Seymore.
The following user(s) said Thank You: Z1Driver
  • Z1Driver
15 Aug 2014 22:55
#644162
Thanks for the heads up on Craigslist. I came here first. Tim
Blue 1975 Z1B
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
15 Aug 2014 23:12
#644164
10-4 Tim...
Might also watch flebay... but I suspect you may have to watch flebay/CL and other places, for a while, to find what you're (specifically) looking for. Just saying that it could take time and a bit of due diligence on your part...
Good luck man...
C.
