Valve Clearance
- koloj
Valve Clearance
13 Aug 2014 20:06
I know been a million threads on this but their like 3 manuals on what the valve clearance should be what would u recommend before I put this engine back on the chassis I want everything to be perfecto u know....I know their are differences to tight and loose but I just had it machined and I'm hoping get many miles out of it...what clearence worked best for everyone...1980 kz750 four....another thing since I have new rings and had it honed how do u go about wearing it in...will I have full compression of the bat also how many miles should I change the oil filter and do a oil change..I'm entering new territory with this high rpm engine rebuild just like the insight from you master kz rebuilders and owners...thanks
- PLUMMEN
Re: Valve Clearance
13 Aug 2014 20:14
Aim for the middle of range on intakes,just a hair on loose side for exhaust valves.
Id put about 50 miles on it myself and dump oil/filter,look for any shiny stuff in the oil.Once the motor has been heated/cooled a couple times retorque the head bolts/nuts.
Re: Valve Clearance
13 Aug 2014 20:20
Here's my experience with my KZ650. I believe the 4 cylinder KZ750 has a very similar layout. I would shoot for the middle. Ed
www.kzrider.com/forum/2-engine/595262-be...ance?start=20#643792
- koloj
Re: Re:Valve Clearance
13 Aug 2014 20:28
What clearance though some say 007 some 009 what be the number for the middle
- PLUMMEN
13 Aug 2014 20:32
What does your manual give for a range on the 750?
- koloj
13 Aug 2014 20:41
Also not to sound dumb were fobi measure the clearance with the lobe pointing in what direction my manual says up like if the lobe was center of a clock at 12 a clock I read somewhere that was wrong why I also don't trust the clearence it gives me in the manual
- koloj
- !Seymore
- Ride on...
13 Aug 2014 23:00
What manual you got? Kawi? Clymers? Haynes?
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- koloj
14 Aug 2014 05:31
Clymers I had to basically goto the bible one eveytime i read something in the clymers pictures are so plain
- koloj
14 Aug 2014 05:34
So when reading shim chart if I have 007 clearence with a 250 shim what would I change it to a 245 or 240
- Markovich
14 Aug 2014 11:32
I have a 1000, that being said my FSM had a very specific position for the cams for each valve to be measured. I measured several at center of base circle thinking that would be acceptable. When I re measured using the FSM I got different measurements. Some on here have thought cam spring action on the cams/bearings have an impact and the positions in the manual compensates for that. I would recommend getting the info from the FSM before taking measurements. Since we have different bikes the FSM for your bike may match Clymers. Good hunting, Keith
1990 KZ1000P, 72k miles, 10 years in storage, new, bars, tires, chain and sprockets, seat, carbs cleaned, police equipement removed.
- koloj
14 Aug 2014 15:09
Okay here is what I got intake
1. 2. 3. 4
012. 005. 006. 011
245. 255. 255. 240
Exshaust
1. 2. 3. 4
007. 009. 008. 006
250. 245. 255. 250
What do u recommend top number is clearence and bottom shim what shims should I get size wise
1. 2. 3. 4
012. 005. 006. 011
245. 255. 255. 240
Exshaust
1. 2. 3. 4
007. 009. 008. 006
250. 245. 255. 250
