Little hiccup
- koloj
Little hiccup
13 Aug 2014 07:38
Okay assembled the engine I notice bad gasket right under can chain tensinor sticking out a bit think it got push out because of the CVT sealer stick in out half way is their high pressure on that gasket I really don't wanna have rip it apart again thinkin CVT seal in it
- 4TheKZ1000
Re: Little hiccup
13 Aug 2014 10:01
Some gaskets will protrude 1/8 to a 1/4 inch in spots, and proud of casting line.
These are other than OEM gaskets and have some extra gasket material......not a perfect fit.
I had this on my bike, no leaks.
Is your gasket within this range? what makes you think the gasket is not placed correctly?
- koloj
