kz 650 rpm limit ?
- insutama
kz 650 rpm limit ?
12 Aug 2014 14:41
Just wondering what is the max rpm you want to cruse with this bike would keeping it at 6000 rpm for say a 2 hr ride be bad for the engine ?
1978 kz650
Re: kz 650 rpm limit ?
12 Aug 2014 14:45 - 12 Aug 2014 15:29
I can't say it would do much harm to the engine, but depending on where you live you may rack up some tickets. On the KZ650 with stock gearing 6000 rpm = 80 mph. Ed
Last edit: 12 Aug 2014 15:29 by 650ed.
- Tyrell Corp
12 Aug 2014 15:17
Rev limit is usually set by valve bounce, where the springs can't shut the valves quick enough -this usually happens well past the redline. Most untuned motors start running out of steam at the redline anyway,
6000 rpm is the average cruising speed of most zeds. All the big 4 cyl zeds are well designed and 30 years later and a dozen or more previous ownersTthey are mostly still ok.
During development Honda had a fireblade engine on a dyno on the redline for 7 days, afterwards it was stipped and found all to be within tolerances.
Don't thrash them when cold and use decent oil . The whole engine 'floats' on oil, apart from cold starts.
- Tyler
12 Aug 2014 20:37
most 650 owners would say 4000 is the "natural" cruising speed of that engine. 6 grand isn't going to hurt it, hell they turn 10,000 or more in stock configuration.
"74 Yamaha DT 400 Enduro
- zukdave
12 Aug 2014 21:44
Point's bounce will shut it off before it rev.'s enough to hurt it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- insutama
12 Aug 2014 23:08
i find that im at about 5 grand going around 110km and im at grand im going around 120 - 125km does this sound right ? or maybe i dont have the stock sprockets ? or maybe speedo is off ?
1978 kz650
13 Aug 2014 04:19
The speedo is off a little which is normal on these bikes. At 5000 rpm you're probably moving at about 66-67mph (106-108kph). Ed
- 4TheKZ1000
13 Aug 2014 10:11
You never want to keep an engine at a steady RPM for a long time. You should vary your RPM for proper engine wear across the RPM range.
If your doing highway riding, you will be in and out of traffic and rpm's will moderate just fine.
- Tyrell Corp
15 Aug 2014 13:00
Maybe not for running -in UK loads of despatch riders bikes have done starship miles mainly done at motorway speed, many done 100k miles plus out of old kawasaki GT550's ,GT750's etc.
Most mega high miler cars and commercial vehicles, some over 1,000,000 miles have clocked 90 percent of their miles on motorways, many in speed limited mode. Not aware of how steady rpm is detrimental to an engine?
