Idle Question
- nickleo373
Idle Question
11 Aug 2014 16:56
Hey everyone
Now that I am able to ride my 81 KZ550 around for longer periods of time I am noticing the idle will increase the longer it stays running. I replaced the carb holders a few weeks ago and have verified there are no more vacuum leaks. The bike is fine for the first 15-20 minutes of running. After that the idle will gradually increase to the point where pulling in the clutch lever at lower rpms will noticeably increase the sound of the engine. Any ideas on what I should be checking?
1981 KZ550C LTD
"If you ain't first, you're last"
- !Seymore
- Ride on...
Re: Idle Question
12 Aug 2014 13:31
This is normal for the older bikes. Just tweak the idle adjustment screw, as needed. This happens on my 650... once up to operating temp, I'll usually turn it down a bit and keep going...
As far as the clutch, no input... sorry.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- bluezbike
Re: Idle Question
12 Aug 2014 18:14
Sounds like your clutch is dragging a little....there should be no increase in rpms when you pull in the lever.....check on the clutch cable adjustment.
79 KZ 1000 LTD
