Engine assembly
  • koloj
  • koloj's Avatar Topic Author
Engine assembly
10 Aug 2014 18:18
#643386
My manual and bible one dont show good enough diagrams were to put gasket sealer on the head gasket and lower under the cylinder one also what adhesive agent do I use on the rubber dampers for the cam chain guard I'm putting it together tommrow so any tips or help is much appreciated.... 1980 kz 750 four or h1 thanks
  • koloj
Re: Engine assembly
10 Aug 2014 18:20
#643388
Rubber dampers
  • baldy110
  • baldy110's Avatar
Re: Engine assembly
11 Aug 2014 14:31
#643513
Don't use sealant on any gasket and I have never used glue on the dampers.
  • willburrrr2003
  • willburrrr2003's Avatar
Re: Engine assembly
12 Aug 2014 09:31
#643623
Sealant on headgasket = BAAAAAADDDDD IDEA.... you will blow through the sealant in short order, and blow the head gasket. You will end up buying a new gasket and rebuilding all over again. I know this from my younger and stupider days ;) . Best of luck on you re-assembly.
Regards,
Will
Regards,
Will R.
