#2 and 3 ignition leads reversed
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
10 Aug 2014 08:16
#643309
In order to adjust my valves I had to take off the ignition coils, and in doing so noticed that the #2 and 3 leads are reversed - that is, the lead that is supposed to go to the #2 cylinder was going to the #3 and vice versa. Now the bike has been running great so I'm actually a little afraid to switch it back to what is right according to the service manual. Shouldn't something horribly wrong have happened if they are indeed reversed?
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Re: #2 and 3 ignition leads reversed
10 Aug 2014 08:29 - 10 Aug 2014 08:30
#643312
No. One coil fires plugs 1&4 and the other coils fires plugs 2&3. These bikes use the wasted spark method. So, for example, when the coil fires plugs 2&3 it fires both plugs at the same time. One cylinder will be at the top of the compression stroke and its fuel charge will ignite, the other cylinder will be at the top of its exhaust stroke and the firing of its plug will do nothing. Because they both fire at the exact same time, it doesn't matter if the #2 wire it on plug #3 and vice versa. The same applies to the coil that fires plugs 1&4. Ed
Last edit: 10 Aug 2014 08:30 by 650ed.
The following user(s) said Thank You: PLUMMEN
  • zed1015
  • zed1015's Avatar
10 Aug 2014 08:33
#643313
2 and 3 run off the same coil and spark at the same time ( with a wasted spark) so it won't make any difference.
Same goes for cyls 1 and 4.
  • Zaddict
10 Aug 2014 08:36
#643314
Ah, nice, that explains why it's still running well. Thanks!
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
