kz400 push rod seal
- shootanappleoffmyhead
kz400 push rod seal
09 Aug 2014 19:11
Hi Guys,
The other day my 77 kz 400 started leaking oil from the clutch push rod seal. This happened after my chain snapped and somehow slightly bent the push rod.
2 things.
1. How in hell do I get the seal out? I've tried everything but dynamite (only because I've run out
2. Does anyone know what part number it is and where i could get both a push rod and seal for a 77 Kz400 s3?
Thanks!
2 things.
Thanks!
- Nebr_Rex
Re: kz400 push rod seal
09 Aug 2014 19:25
Part is no longer available. Post a pic. There is a fix using a valve guide seal.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
09 Aug 2014 19:50
Here's one. They're in New Zealand, but I've bought from them before and was pleased. Ed
www.plenternz.com/advanced_search_result...m8atqvg95phfj0hs3456
Attachment 00003_2014-08-09.jpg not found
The following user(s) said Thank You: shootanappleoffmyhead
09 Aug 2014 21:11
Thanks guys. Ok, I've got the replacement parts lined up. I'll probably end up just using 1/4" stainless round stock for the push rod. Now that leaves me with one last thing... how to get the seal out. I've tried pulling it out w/ a needle nose, screwdriver, etc. Nothing works. It's really in there.
Here's a pic.
Thanks!
Here's a pic.
Thanks!
- Michel3007
27 Feb 2022 03:18
Hi,
Could it be possible to have access to the archive linked in this thread ?
I have the same leak but cannot see anything when clicking on the link provided by Patton.
Thank you
Thank you
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
