Oil sending unit 1976 900 (Ltd)
  • Peppermint Patti
  • Peppermint Patti's Avatar Topic Author
09 Aug 2014 09:48
#643219
Hi! I'm new here and an ancient 900 Kaw dragracer.
My friend has the above mentioned bike. How do you know if the oil sending unit is bad?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Oil sending unit 1976 900 (Ltd)
09 Aug 2014 10:10
#643221
Is the oil light coming on?
You could screw an oil pressure gauge on the motor to check,they only run about 3-5 psi of oil pressure most of the time,so don't be surprised if the gauge shows low numbers. ;)
