cam degree question
- Powerstroke_fan
cam degree question
04 Aug 2014 06:34
Hey guys. I switched to a regular kz style head from a j model head. My cams need redegreed. But iam running a thick base gasket and my tdc tool wont reach the top of the piston with the washer on the tool. With the spacer removed it hits the valves. I do have the tdc side walls ground down. But not the tip. My question is. I should be able to grind down the spacer for the tdc tool so it will reach the piston correct? As long as i dont adjust it after i take my first measurement? Thanks.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Powerstroke_fan
Re: cam degree question
05 Aug 2014 04:09
Anyone have any ideas?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
