Won't Start when already warmed up
  • tooltyme
  • tooltyme's Avatar Topic Author
03 Aug 2014 15:00 - 03 Aug 2014 18:20
#642592
1979 KZ 650 I only have the kickstart working one this bike, This year it will start fine cold at first when going to ride, But after running it or drive for a bit the bike doesn't want to start again until it has cooled off??????????
Last edit: 03 Aug 2014 18:20 by Patton.
Re: Won't Start when already warmed up
03 Aug 2014 15:14
#642594
While the bike is cold try heating up the coils with a hair dryer. If the bike won't start with warm coils and a cold engine they probably are at fault. Ed
03 Aug 2014 18:22
#642611
tooltyme wrote: 1979 KZ 650...will start fine cold at first when going to ride, But after running it or drive for a bit the bike doesn't want to start again until it has cooled off??????????
Would check valve clearances to assure being within specs, as too tight valves may result in the reported symptoms.
Good Fortune! :)
