re assembly 1980 kz1000
  • 771000LTD
  • 771000LTD's Avatar Topic Author
03 Aug 2014 00:31
#642553
I have been trying to re assemble engine and had placed the base gasket in position. Now the gasket has been soaked in oil but no pressure applied,can i still use this gasket? Not torn or misshapen ,just oily. Thoughts?
Thanks
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
Re: re assembly 1980 kz1000
03 Aug 2014 00:42
#642554
I would replace it. Make sure all contact areas are oil free when you do it again
The following user(s) said Thank You: PLUMMEN, 771000LTD
  • 771000LTD
03 Aug 2014 00:50
#642555
WTF up @ 3:30 on sun morn...something got to give!
  • etbike3135
  • etbike3135's Avatar
03 Aug 2014 05:49
#642564
Oil soaked gaskets are your friend. Go ahead and use it. I spray all gaskets with WD 40 before I put them on. Makes them easier to get off.
1973 Kawasaki Z1
18 years in dragbikes
  • 771000LTD
03 Aug 2014 06:10 - 03 Aug 2014 06:16
#642565
Thanks but if I don't have to take it off again,i'm happy.I agree it should be OK since it was not molested. It should be noted that I don't molest gaskets, lately.....mostly...........usually sometimes....
Last edit: 03 Aug 2014 06:16 by 771000LTD.
