kz1000 1981 strange sound coming from engine
  • war113
  • war113's Avatar Topic Author
02 Aug 2014 22:20
#642545
Hi all!
I'm new but I am looking for help.KZ1000 CSR 1981 32 000 km (only)
I made a video of my KZ engine running:
Symptoms:
Engine sometimes stay stuck at higher rpm then calms itselfs.
At first it stalls on idle.
What I will do:
Seafoam as the bike didnt run for over a year,
Spark plugs and oil change done.
I'll post if the seafoam helped..I would like to get advices still.Oh and both the RPM and SPEED gauges got changed by PO.The speed one works well..The rpm is stuck at 6000 even when bike is idling at 1200.If I turn the gaz on a bit it will go up but its like if 6000 was 0 RPM....
  • peter1958
  • peter1958's Avatar
Re: kz1000 1981 strange sound coming from engine
02 Aug 2014 22:28
#642546
You need to adjust the cam chain.
  • war113
02 Aug 2014 22:32
#642547
Okkkk...DO I have todissasemble the whole engine for that?
  • peter1958
  • war113
02 Aug 2014 23:37
#642550
thanks alot!
