kz 1100 need advice
- danny4748
02 Aug 2014 18:09 #642508
by danny4748
kz 1100 need advice was created by danny4748
I have a KZ 1100 that a friend brought over. it seems to have know or very little compression in the left side cylinder but the right sight seems ok. I dont have a compression gauge so i used a finger of the plug hole while turning itr over. seems like the starter is dragging. I have downloaded a manual but could use some advice on how to proceed.
thatk you for any help.
- Z1Driver
- love the smell of triple smoke
- Thank you received: 55
02 Aug 2014 20:18 #642540
by Z1Driver
Blue 1975 Z1B
Red 2009 Concours 14
Replied by Z1Driver on topic kz 1100 need advice
Valve lash in tolerance?
Blue 1975 Z1B
- danny4748
03 Aug 2014 17:59 #642609
by danny4748
Replied by danny4748 on topic kz 1100 need advice
I will check that.
- PLUMMEN
- Thank you received: 104
03 Aug 2014 19:00 #642613
by PLUMMEN
Replied by PLUMMEN on topic kz 1100 need advice
Borrow or buy a compression testor from auto parts store to check the compression,then check valve clearances.
Be sure to hold throttle wide open when testing compression.
