KZ440 kickstarter swap. Anyone done it?
- Mercury Kid
28 Jul 2014 14:04
Got a kz400 project that I'm swapping a 440 motor into and I want to keep the kicker. I've got the cases split and have all the kicker parts swapped over but when I button it up the crank won't spin and all I can see causing it is the kicker gear. I tried swapping out the first gear cog from the 400 since theyre different, but it won't work on the 6spd 440 trans.
So is this possible? Do I need a different size kicker gear? From what? The 6spd trans is more important than a kick starter but having both would be the best.
'76 KZ900-Z1 clone
Z1 70's period longbike
- Nebr_Rex
Re: KZ440 kickstarter swap. Anyone done it?
28 Jul 2014 15:08
You have to use the "79-"80 KZ400 parts for a direct bolt in replacement.
Or do like I did and machine both first gear gears down. The trans shafts are the
same size and spline.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Mercury Kid
29 Jul 2014 05:40
Cool, cause I think I have those too. Do I need just the kicker parts to do this or the first gear stuff as well?
'76 KZ900-Z1 clone
- Mercury Kid
29 Jul 2014 08:47
So the 900/1000 kicker gear works if you pull the bushing from the 400 gear and fit it in the 900 gear so that it fits the smaller shaft. And then grind down the spacer to make up for the gear being wider. Seems to be working on the bench, we'll see what happens in the bike.
'76 KZ900-Z1 clone
- Nebr_Rex
29 Jul 2014 18:53Mercury Kid wrote: So the 900/1000 kicker gear works if you pull the bushing from the 400 gear and fit it in the 900 gear so that it fits the smaller shaft. And then grind down the spacer to make up for the gear being wider. Seems to be working on the bench, we'll see what happens in the bike.
Where did you get this 900/1000 idea?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Mercury Kid
06 Aug 2014 21:03
It was what I had available. Figured it was worth a shot
'76 KZ900-Z1 clone
