cam seal installation tool
  • happyhunter
  • happyhunter's Avatar Topic Author
27 Jul 2014 13:08
#641628
I have an 82 305 CSR I want to replace a leaking cam seal on. The manual says to use "oil seal driver (special tool)" and it has a number "57001-1022".
I am guessing the dealer could sell me such a piece. Is there a low cost tool that would work well? Or am I best to buy the real McCoy?
Thanks,
HH
'82 Kawasaki KZ305CSR
I did not set out to buy a project bike,
but I got one anyway.
  • Motor Head
  • Motor Head's Avatar
Re: cam seal installation tool
27 Jul 2014 13:16
#641629
Deep Well Socket the right diameter will work just fine. I lube the seal inside surface first with Sil-Glide, a silicone based grease. And then I like Anaerobic sealer around the outside to help both instal the seal and glue it in place.
The following user(s) said Thank You: PLUMMEN
  • peter1958
  • peter1958's Avatar
  • Banned
  • Banned
27 Jul 2014 15:52 - 27 Jul 2014 15:54
#641647
Last edit: 27 Jul 2014 15:54 by peter1958. Reason: z
  • happyhunter
27 Jul 2014 20:05
#641688
Peter,
I did see the tool on ebay. ouch for just one time use....
Motor Head,
what is Anaerobic sealer? Is there a brand I should look for?
Thanks,
HH
