engine set up to run 9s in 1/4
  • 69newportking
  • 69newportking's Avatar Topic Author
24 Jul 2014 10:10
#641219
What kind of engine modifications /horsepower/setup does it take for a kz to run in the mid to high 9s in the 1/4 mile ?
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: engine set up to run 9s in 1/4
24 Jul 2014 10:31
#641222
That's a really open ended question. Are you talking street trim or race only with a slick and wheelie bars?
Typically a race bike will be lighter and can leave much harder with wheelie bars and a slick than a streetbike with all the lights etc. Pretty much what I'm saying is a smaller engine can be used if the bike is built to be lighter and setup for drag only.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: PLUMMEN
  • StreetfighterKz
24 Jul 2014 10:32
#641223
Also, do you want a N/A engine or a boosted/sprayed combo?
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • steell
  • steell's Avatar
24 Jul 2014 10:48
#641224
Buy a ZX14R and put Ricky Gadson on it to run 9.3X with a ~190 rwhp 500 lb bike and whatever Ricky weighs.
I'm pretty sure you're looking at a turbo or nitrous to get there on a KZ.
Or a 1500cc big block race motor.
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
24 Jul 2014 10:58
#641227
Hi 9's or low 9's...there is a big difference there too.
Like Doug said, not enough info unfortunately. Rider weight, bike weight, kind of tire, how good you are at launching the bike, etc....people have run 9's with 1075's and smaller. Depends on the rest of the package.
Build Thread
24 Jul 2014 11:14
#641231
Why 9's? Why not low to mid 8's? Just get a KZ750 Turbo and spice it up a little. :cheer:
Take a look at the link for ideas. Ed
www.750turbo.com/forum/viewtopic.php?f=9...377&p=120771#p120771
Attachment 00007_2014-07-24-2.jpg not found
  • zukdave
  • zukdave's Avatar
24 Jul 2014 17:25
#641277
Easy to go 9's.
A few beer's and a lot of these $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
24 Jul 2014 18:36
#641297
Hope you got Lots of Money to play in the race game.
And a large pair of stones to ride a bike like that at maximum potential.
I used to
, Now I just shift out of 2nd at 110 and climbing and call it good.
Or call Terry Kizer at MR Turbo and start writing checks
  • racer54
  • racer54's Avatar
25 Jul 2014 07:42
#641362
Guy around here with a dragbike....no wheelie bars but a slick and slider set up soft. 1105cc...11-1 compression...self ported head...36mm Mikuni's.....420 lift cams.....1-2 auto trans. and he runs 9.2-9.3 all day long. Good rider with right set-up chassis should be able to get into the nines with good street tire. This bike is probably aound 66"-68" long. I've seen a ELR running a 1200cc motor with .425 cams....ported head but with stock wheelbase and stock size tire. This bike looks stock. He was running 10.2's while coming off the line on the soft side. Lots of ways to get there. Slick and bars is much easier way to get there but can be done with street tire bike with right set-up and learning how to ride.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
25 Jul 2014 09:14
#641370
I went to high school with Tom Houseworth and he had a 9 second Z1R then that he always claimed was "stock" :laugh:
  • zukdave
  • zukdave's Avatar
25 Jul 2014 16:25
#641420
Like racer said a good chassis. It'll take low 1.5 high 1.4's 60ft
or you better have a damn good back half.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
