camshaft powerbands
- 69newportking
camshaft powerbands
23 Jul 2014 14:18
I have two cams one is a .410 lift .266 duration. And the other is a .395 lift .256 duration . Was wondering what the power band was on these cams the .395 I had in my old motor and it started pulling around 4000 rpm but was a dog below that . I read that the .410 is something like 6500 rpm and up before it pulls . What doing u have in your bikes ? And we're is your power band at ? Am in the process of selecting a cam to install . At the moment I think am going with the .395 cause the head is already clearance for the lobes. has high performance valve springs install. I don't really have a lot of money to spend . Am trying to stay away from shim under buckets .and over sized any thing . What are your thoughts ?
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: camshaft powerbands
23 Jul 2014 14:56
In a nutshell, the lower lift and shorter duration will give you a (little) less top end with the benefit of a (little) more bottom end
- PLUMMEN
23 Jul 2014 17:37
What size id the motor/comp/carbs?
How will the bike be ridden most of the tine?
- 69newportking
24 Jul 2014 03:02
1135cc ,10.5cr ,stock valves , ported head ,34mm rs Mikunis. 6" Extended swingarm , dyna2000 ign. 3.0 ohm coils. Making a pro street out of it . I do plan on riding on the street but just like to car shows around town no more then 5 miles no freeway . But I still want something that will be competitive at the track . By the way what kind of horsepower do u think it will make ? And et with 170lbs rider ?
- etbike3135
24 Jul 2014 04:17
You might want to check your duration @ what lift. I do recall the 395 cam has 256 duration @ .05 and usually the 410 cams have in the 260 range
1973 Kawasaki Z1
18 years in dragbikes
- 69newportking
24 Jul 2014 04:38that's what I put but sorry forgot to put @.05069newportking wrote: I have two cams one is a .410 lift .266 duration. And the other is a .395 lift .256 duration .
- PLUMMEN
24 Jul 2014 08:30Id make a wild guess of around 120hp at the rear wheel with the ,410s.69newportking wrote: 1135cc ,10.5cr ,stock valves , ported head ,34mm rs Mikunis. 6" Extended swingarm , dyna2000 ign. 3.0 ohm coils. Making a pro street out of it . I do plan on riding on the street but just like to car shows around town no more then 5 miles no freeway . But I still want something that will be competitive at the track . By the way what kind of horsepower do u think it will make ? And et with 170lbs rider ?
Track times depend on too many different variations.
- 69newportking
24 Jul 2014 09:56
For 1977 kz 1000 the book says 83 horsepower .is that at the motor or the wheel ?
- steell
24 Jul 2014 10:5269newportking wrote: For 1977 kz 1000 the book says 83 horsepower .is that at the motor or the wheel ?
As far as I know, all advertised hp is at the crank.
- tachrev
- Rubber Side Goes Down
24 Jul 2014 10:54steell wrote:69newportking wrote: For 1977 kz 1000 the book says 83 horsepower .is that at the motor or the wheel ?
Yep, pretty sure you would find 60 to 70 hp at the wheel on a stock KZ1000.
Build Thread
Build Thread
- PLUMMEN
24 Jul 2014 22:59
I saw a stone stock kz1000 with 26s and stock airbox and an old kerker make 75-76 at rear wheel.
- tachrev
25 Jul 2014 07:29PLUMMEN wrote: I saw a stone stock kz1000 with 26s and stock airbox and an old kerker make 75-76 at rear wheel.
Well there you go. I was just guessing (a little low apparently), but here is the voice of experience.
Build Thread
Build Thread
