Complete gasket set?
- fmxr47
23 Jul 2014 05:01
Hey guys I'm looking for a complete gasket set that includes the shift shaft seal, counter shaft seal and kick shaft seal, just picked up this 1978 kz650sr with 23k on the clock and the engine has good compression but the bottom pan leaks a good bit of oil and the output shaft, I'm going to get a complete set so I can fix the leaks now and ride and then do a teardown this winter. Any input appreciated.
- baldy110
Re: Complete gasket set?
23 Jul 2014 08:18 - 23 Jul 2014 08:19
No one makes a complete gasket set with the seals you want. You have to purchase a seperate seal kit for that. You can find them on Ebay.
Last edit: 23 Jul 2014 08:19 by baldy110.
- fmxr47
23 Jul 2014 13:54
Thank you! I'm learning a lot about these bikes just on this forum
