Crankcase assembly questions
- jumpship
17 Jul 2014 21:08
Hey guys u probably know me as the guy who punched a hole through his crankcases, well anyways anyways I got a new set of cases now my question is after I got the mating surfaces clean and bonded up, when I put upper case back onto the lower, should it literally fall I to place? Or will I need some persuasion with a rubber mallet to get them cases to squeeze together? And also the factory manual says to torque the crankshaft bolts initially to 132 lbs inch, and than re torque them all to 216 lbs of force!!!:eek: is that even serious??? I re-read it over and over and I find that seriously hard to believe that's possible without snapping on then 8 mm bolts..... or is this the way kawis are? Suzuki crankshaft bolts are done @ 12 lbs inch
1981 KZ750-4
Rode GS's all this time and once i hoped on a KZ... well... hence the name!!
- PLUMMEN
Re: Crankcase assembly questions
17 Jul 2014 21:36
Theyre talking about the big bolts around crankshaft area
- bluezbike
17 Jul 2014 23:14
For goodness sake make sure you have your units correct.....it's not lbs inch, nor is it lbs of force!!!! it's inch/pounds and 12 inch/pounds is equal to 1 foot/pound. The manual specifies that those 8mm bolts holding the crank to the upper case half as well as the crank cap should be tightened first to 11 foot/pounds (or 132 inch/pounds) then to 16.5 to 19.5 foot/pounds (or 198 to 234 inch/pounds) Heck yes you would strip your brand new cases apart if you applied 234 lbs. of force!!!! :ohmy:
79 KZ 1000 LTD
18 Jul 2014 05:13 - 18 Jul 2014 05:31jumpship wrote: ...... And also the factory manual says to torque the crankshaft bolts initially to 132 lbs inch, and than re torque them all to 216 lbs of force!!!:eek: is that even serious???
This makes no sense; exactly what manual are you reading this from? "216 lbs of force" is not a torque spec at all since it doesn't indicate INCH pounds; FOOT pounds; or any other torque unit.
Also - what are "crankshaft bolts"? I don't believe there is such a thing. Are you talking about connecting rod nuts? If so, you REALLY need to get someone to send you the specs from the Kawasaki Service Manual. 216 is wrong whether it was meant to say FOOT pound or INCH pounds - so do yourself a big favor and take a look at the specs in the real manual.
jumpship wrote: Suzuki crankshaft bolts are done @ 12 lbs inch
This makes no sense at all. 12 lbs inch is not even finger tight. That is WAY too light for anything at all on a motorcycle. Ed
I suggest you take a very careful look at all the torque specs before reaching for the wrench and make darn sure you understand the difference between FOOT pounds and INCH pounds, and get someone to post the specs from a KZ750 Kawasaki Service Manual. Ed
Last edit: 18 Jul 2014 05:31 by 650ed.
- jumpship
18 Jul 2014 08:54
Oh son of a gun there are a ton of typos I'm sorry I'm using my smart phone it just auto, corrected while I was typing
1981 KZ750-4
- jumpship
18 Jul 2014 08:59
I'm gonna correct the post when i get home and see the manual,. I have the factory manual
1981 KZ750-4
- jumpship
18 Jul 2014 09:00I see ur a good mistake corrector, i did ask a good question in plain English that u didn't answer, does the crankcase fall right into place or does it usually require some rubber mallet650ed wrote:jumpship wrote: ...... And also the factory manual says to torque the crankshaft bolts initially to 132 lbs inch, and than re torque them all to 216 lbs of force!!!:eek: is that even serious???
1981 KZ750-4
The following user(s) said Thank You: ezrider714
- PLUMMEN
18 Jul 2014 09:16 - 18 Jul 2014 09:19Im referring to the 8mm bolts that hold the area around the crankshaft together that ape sells stud kits for.650ed wrote:jumpship wrote: ...... And also the factory manual says to torque the crankshaft bolts initially to 132 lbs inch, and than re torque them all to 216 lbs of force!!!:eek: is that even serious???
:)And yes,its definitely inch lbs of torque.
Last edit: 18 Jul 2014 09:19 by PLUMMEN.
- zed1015
18 Jul 2014 09:47jumpship wrote: i did ask a good question in plain English that u didn't answer, does the crankcase fall right into place or does it usually require some rubber mallet
If done correctly there should be no mallet or other force needed and everything should easily "fall" in to place.
The following user(s) said Thank You: PLUMMEN
- jumpship
18 Jul 2014 14:45
awesome ur guys are the best, and plummen yes those are the bolts i was talking about as well, the bolts that go over the crankshaft, aka crankshaft bolts. i guess they people call em different things
1981 KZ750-4
18 Jul 2014 15:07jumpship wrote: awesome ur guys are the best, and plummen yes those are the bolts i was talking about as well, the bolts that go over the crankshaft, aka crankshaft bolts. i guess they people call em different things
Those are main bearing studs (case studs). Bolts have threads only on one end; stud are threaded on both ends. Ed
- PLUMMEN
18 Jul 2014 16:09
I didnt have a picture handy of a set of cases with with the bolts, thats why I used the ape picture instead.
