Engine noise
- Terryb505
Engine noise
17 Jul 2014 11:59
Hello gentlemen. I have a slight to moderate ticking in my 78 kz1000. Is there any flood way of determining weather it's cam chain or valve related. Thank you
Terry
Terry
Terry
- PLUMMEN
Re: Engine noise
17 Jul 2014 12:27
Is it doing it when the motor idles then goes away when you give it a little gas?
- Terryb505
Re: Engine noise
17 Jul 2014 13:23
It does seem to be more noticable at idol than when I rev it up. But I do have a 4 into 1 header which is kinda loud.
Thanks again
Terry
Thanks again
Terry
Terry
- Mcdroid
- Gone Kwackers
Re: Engine noise
17 Jul 2014 13:27
Can you isolate the 'ticking'? Front of motor? Top of motor (use a large screwdriver as a stethoscope)? Could be something as simple as as exhaust leak or perhaps more complicated.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- pete greek1
Re: Engine noise
17 Jul 2014 14:17
Like Mcdroid said, could be an exhaust leak,. did you remove old exhaust gaskets, & replace with new copper gaskets ?
Pete
Pete
- PLUMMEN
Re: Engine noise
17 Jul 2014 15:41
The cam chain will make a little noise sometimes at lower rpms when the motor is cold or carbs are out of synch.
