Norris 440SC cam info needed.
  • Dr. Gamma
  • Dr. Gamma's Avatar Topic Author
16 Jul 2014 22:13
#640337
Been going through my collection of parts from my two disassembled KZ1000 Superbike motors trying to see what I can come up with as far as a nice streetable motor. I have two nice cylinder heads to choose from.
What I need to know do the Norris 440SC cams have the same base circle as stock cams??? If so I will be able to run my Yoshimura Super Bonneville cams in the head that was set up to run the 440SC cams. I think the Yosh cams would make a nicer street setup than a motor with the 440SC cams. I found the lift and duration specs for the 440SC cams, but nothing on the base circle so far.
1986 RG500G 2 stroke terror.
  • bluezbike
  • bluezbike's Avatar
Re: Norris 440SC cam info needed.
16 Jul 2014 23:34 - 16 Jul 2014 23:36
#640343
Dr.G.....I have a set of Norris 440 cams which I just measured and unfortunately :( the base circle is smaller than stock. The measured out to 27.4 mm. or 1.080"
79 KZ 1000 LTD
Last edit: 16 Jul 2014 23:36 by bluezbike. Reason: spelling
  • LarryC
  • LarryC's Avatar
17 Jul 2014 05:00
#640351
The smart move is to measure the cams you have in your hand. Specific grind numbers do not always mean the base circle of that particular grind will be the same for every one ground. People do order custom base circles.
Larry C.
The following user(s) said Thank You: bluezbike, Dr. Gamma
