Will I die if I disregard this crack?
11 Jul 2014 17:58 #639758 by DobbinsCMA
Will I die if I disregard this crack? was created by DobbinsCMA
I found two cracks in the engine as I was dissembling. What will happen if I just build the engine and ride it? Is it dangerous if I run it into the ground?
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • 4TheKZ1000
  • Visitor
11 Jul 2014 18:17 - 11 Jul 2014 18:17 #639760 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Will I die if I disregard this crack?
Well, your BALLS are pretty well protected by the battery and frame.
Might lose a foot at the ankle, but you could still procreate.....BUT after this question, it might be a good idea to keep your swimmers to yourself.
Last edit: 11 Jul 2014 18:17 by 4TheKZ1000.
11 Jul 2014 18:18 #639761 by 650ed
Replied by 650ed on topic Will I die if I disregard this crack?
Yes; it is dangerous. Envision a catastrophic engine failure while traveling in traffic (especially on a highway) with cars and/or trucks directly behind you. Not healthy! Also, such a failure while running through a turn or other circumstances could lead to a stay in an emergency room (or worse). I would consider riding a bike with such a seriously cracked engine to be similar to playing Russian roulette. Ed
The following user(s) said Thank You: DobbinsCMA
11 Jul 2014 18:31 #639763 by bluezbike
Replied by bluezbike on topic Will I die if I disregard this crack?
+2,3,4......Think of what it took to get that motor to that point, the two breaks you mention and the badly torn main output shaft bearing I saw in your other post. I suspect a real catastrophic event took place and I would put money on more damage existing you haven't even uncovered yet. I cannot imagine that 650 motors are that hard to find or that costly, certainly when compared to your wellbeing :)
79 KZ 1000 LTD
11 Jul 2014 18:39 #639765 by DobbinsCMA
Replied by DobbinsCMA on topic Will I die if I disregard this crack?
1000...Well I just bought all the parts required to fix it. Bolts, Pistons, Boring, Gaskets, Frame painted, Tank painted, New Electrical. About 2000 dollars already spent. New engine from that guy in Florida is 4000. There a couple motors near me called Suters Speed Shop but I think he wants like 800-1000. I guess I didnt think about what would happen to the crack under pressure. If anyone knows of a mid engine (which is the rarest to come by as it has the serial number right?) let me know?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
11 Jul 2014 19:01 #639768 by bluezbike
Search Craigs List for a complete (or not) bike, especially with no title just for the motor, you might have a little luck.....as you already have bought parts look for something that will give you a decent looking set of cases and still build your motor from scratch. Ebay may be a source just for a set of cases, they run well under $100
79 KZ 1000 LTD
11 Jul 2014 19:09 #639770 by DobbinsCMA
What years am I looking for? What bottom ends will work with what I got?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
11 Jul 2014 19:11 #639771 by PLUMMEN
Replied by PLUMMEN on topic Will I die if I disregard this crack?
Check kz650.info forum,lots of parts floating around there. :)
11 Jul 2014 19:14 #639772 by DobbinsCMA
...I have a 1000...Will they have those parts in the 650 forum?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
11 Jul 2014 19:17 #639773 by floivanus
Replied by floivanus on topic Will I die if I disregard this crack?
Why not check here? There's bound to be someone that has good cases here, I am certain I have a goid set of 1000 cases but I believe those to be J model ones, might be able to find a set of early kz cases, if I have a good set (should only get a matching set PERiOD) I would send them for shipping cost
Past; 78 kz1000, 83 kz550
Andrew
11 Jul 2014 19:22 #639776 by PLUMMEN
DobbinsCMA wrote: ...I have a 1000...Will they have those parts in the 650 forum?
Sorry thought you were talking about the 750.
Check with kz1006,hes a member on here for 900-1000 parts. :)
11 Jul 2014 22:29 #639790 by DobbinsCMA
do you mean kz10006?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
The following user(s) said Thank You: PLUMMEN
