1980 KZ100 LTD Re-assembly
  • 771000LTD
  • 771000LTD's Avatar Topic Author
11 Jul 2014 15:10
#639733
Trying to reassemble this bike that I tore down to the frame.Now putting the engine back together and getting stuck with the jugs. All pistons except #1 go in no problem,#1 will not go past the oil rings. I now have removed the jugs and the piston.I have tried different rings ,different piston with the new rings. I have a set of other pistons that has not been cleaned,and the rings intact and they slide no problem. Going CRAZY! Any Help?
Re: 1980 KZ100 LTD Re-assembly
11 Jul 2014 15:17
#639735
Did you set the gap on the rings? Ed
  • 771000LTD
11 Jul 2014 15:37
#639738
No I havent.Bought these from a shop in England. I was told that I didn't need to gap them. I used these rings in my 77 re build and they working great(touch wood) and 2,3 and 4 are going in with no problems on this engine. Tore it down over a year ago,don't know if that has any bearing.
11 Jul 2014 15:47
#639740
I would at least check the ring gaps. They may be fine, but better safe than sorry. Ed
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
11 Jul 2014 15:50
#639741
With the money I spent on my bike, one reason I sleep good at night is..... the numbers all added up and were correct.
You were told or you assumed is bad math. Slow down and put in the work.
Good luck
  • koolaid_kid
  • koolaid_kid's Avatar
11 Jul 2014 16:39
#639748
650ed wrote: I would at least check the ring gaps. They may be fine, but better safe than sorry. Ed
As Ronny Reagan once said: Trust, but verify".
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • 771000LTD
11 Jul 2014 16:55
#639749
It would appear that the to oil rings and the corrugated copper in the middle are binding and not letting the rings move and therefore not compressing and thus impeding the pistons path into the bore.
That being said,don't know how to remedy the problem
My thanks to:
Ronny Reagan
Sleeping beauty
And ED!
