Piston Ring's Gap 72mm
- bountyhunter
Re: Piston Ring's Gap 72mm
10 Jul 2014 17:00 - 10 Jul 2014 17:02DobbinsCMA wrote: That is a good point. I guess I could but maybe I should get some. Though I do not appreciate your negative judgmental tone. This a place to help people not to be a jerk. Notice how 4TheKZ1000 said the same thing but not in a way that made him look like an condescending arse. I do not do this for a living nor do I pretend to be a professional so I understand that I may be a little ignorant.
Now back to my initial question of the gap for 72mm rings. Since you are so very experienced do you think you could give me a double check on my math? That would be most helpful Dr Gamma.
According to my math:
72mm = 2.83"
nominal ring end gap should be about .009" - .011"
Slightly too much gap is not a problem, too tight can cause rings to break when they heat up.
Last edit: 10 Jul 2014 17:02 by bountyhunter.
The following user(s) said Thank You: PLUMMEN, DobbinsCMA
thats a big 10-4.
if ring ends expand and touch it,it is trying to rip the top of the piston off.
- DobbinsCMA
11 Jul 2014 13:47 - 11 Jul 2014 13:48
I totally see what you mean about te "feel" with the metal. Though roughly they gave the same results the metal allowed me to see how much to take off one of the piston rings. I rounded up just to be safe because at 500 dollars a set for the pistons; id rather not have them get ripped apart.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
Last edit: 11 Jul 2014 13:48 by DobbinsCMA. Reason: Fat fingers
- PLUMMEN
11 Jul 2014 19:27
Come on now,how many of you have been around long enough to remember using a match book cover to set points?
Hold up your hands! :woohoo:
- Z1Driver
- love the smell of triple smoke
11 Jul 2014 22:29
I have to raise my hand on this one because in a pinch a match book cover worked not only to set the points put to make sure they were clean after using the feeler gauge.
I own a couple of feeler gauges because they keep walking off.
Blue 1975 Z1B
Red 2009 Concours 14
- peter1958
12 Jul 2014 02:56
It was a match book cover for the spark plug in the lawnmower.
www.kzzone.com/
12 Jul 2014 07:17PLUMMEN wrote: Come on now,how many of you have been around long enough to remember using a match book cover to set points?
Attachment bumputertriperaisedhand.jpg not found
14 Jul 2014 05:53PLUMMEN wrote: Come on now,how many of you have been around long enough to remember using a match book cover to set points?
- koolaid_kid
14 Jul 2014 05:56
I was never allowed to play with matches. :ohmy:
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
