Piston Ring's Gap 72mm
- DobbinsCMA
10 Jul 2014 12:31 - 10 Jul 2014 12:41
So do I need to check the ring gap in the cylinders? Do I do this from the top or the bottom of the cylinders?
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
Last edit: 10 Jul 2014 12:41 by DobbinsCMA.
- 4TheKZ1000
Re: Piston Rings 72mm
10 Jul 2014 12:34 - 10 Jul 2014 12:37
yep, you need to set ring gap.
where the two ends of the ring come toghter when placed in cylinder bore, manufactures recommend a certain clearance.
I would push ring down about 1/2" in the bore to measure gap.
Last edit: 10 Jul 2014 12:37 by 4TheKZ1000.
- bountyhunter
Re: Piston Ring's Gap 72mm
10 Jul 2014 12:44I think you check it at several points up and down the bore, haven't done it in a while. I recall the proper nominal end gap is about .003" - .004" of end gap PER INCH OF BORE DIAMETER.DobbinsCMA wrote: So do I need to check the ring gap in the cylinders? Do I do this from the top or the bottom of the cylinders?
I think service limit is actually about double nominal which sounds like a lot but there isn't that much compression loss at the end gap point, most of it is past the rings in the piston grooves.
- DobbinsCMA
10 Jul 2014 12:52
That means I should be able to get 10 sheets of paper between the ends of my ring? Cuz it looks pretty small in my picture. 1 sheet a paper is 1 mil or .001 inches. What do you think about the gap?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- Dr. Gamma
10 Jul 2014 12:59DobbinsCMA wrote: That means I should be able to get 10 sheets of paper between the ends of my ring? Cuz it looks pretty small in my picture. 1 sheet a paper is 1 mil or .001 inches. What do you think about the gap?
No, you go buy a set of feeler gauges.
10 pieces of paper, give me a break.
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: Nessism, peter1958
- 4TheKZ1000
10 Jul 2014 13:07
go to AutoZone and spring $8 for feeler gauge........ :whistle:
- DobbinsCMA
10 Jul 2014 13:10
Well I have this cool thing called a micrometer that measure to the ten thousandths place of an inch. I measured each page (thicker pages than normal paper) as being .01145 or .011. That being said, yes I would love some but why buy them for one use? Do you want to send me the money? Give me a break. Normally yes I would agree that the right tools matter when doing such important measurements. But thank you Dr Gamma for your reply.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- DobbinsCMA
10 Jul 2014 13:12
What I am asking is .0113 inches the right gap at .004 for these rings? Thats all.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- Dr. Gamma
10 Jul 2014 13:15
Stupid question for you Mr. Dobbins, what are you planning to use when you check your valve clearance??
That fancy micrometer??
The following user(s) said Thank You: peter1958
- DobbinsCMA
10 Jul 2014 13:31
That is a good point. I guess I could but maybe I should get some. Though I do not appreciate your negative judgmental tone. This a place to help people not to be a jerk. Notice how 4TheKZ1000 said the same thing but not in a way that made him look like an condescending arse. I do not do this for a living nor do I pretend to be a professional so I understand that I may be a little ignorant.
Now back to my initial question of the gap for 72mm rings. Since you are so very experienced do you think you could give me a double check on my math? That would be most helpful Dr Gamma.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
10 Jul 2014 13:41 - 10 Jul 2014 13:48
Wiseco recommends setting the top ring gap using this formula-(bore size(in inches)) X .0040 Say your bore size is 80mm then 80/25.4(mm/in)
.15 in. X.004= 0.012 in. end gap
www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
you would not want to use paper because you want to be able to "feel" the drag of the feeler gauges.
rings are either cast iron or chrome-moly,which are both much harder than paper and would be impossible to get the same "feel"twice .
hth,
hth,
Last edit: 10 Jul 2014 13:48 by 531blackbanshee.
The following user(s) said Thank You: PLUMMEN, DobbinsCMA
- PLUMMEN
10 Jul 2014 13:49
It also helps to make sure piston is sitting level/square in the bore when measuring.
Take a piston and shove it in upside down in the bore using it to square the ring up about midway down the bore, pull piston back out before measuring.
The following user(s) said Thank You: DobbinsCMA
