Piston Ring's Gap 72mm
  • DobbinsCMA
  • DobbinsCMA's Avatar Topic Author
10 Jul 2014 12:31 - 10 Jul 2014 12:41
#639606
So do I need to check the ring gap in the cylinders? Do I do this from the top or the bottom of the cylinders?
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
Last edit: 10 Jul 2014 12:41 by DobbinsCMA.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Piston Rings 72mm
10 Jul 2014 12:34 - 10 Jul 2014 12:37
#639607
yep, you need to set ring gap.
where the two ends of the ring come toghter when placed in cylinder bore, manufactures recommend a certain clearance.
I would push ring down about 1/2" in the bore to measure gap.
Last edit: 10 Jul 2014 12:37 by 4TheKZ1000.
  • bountyhunter
  • bountyhunter's Avatar
Re: Piston Ring's Gap 72mm
10 Jul 2014 12:44
#639613
DobbinsCMA wrote: So do I need to check the ring gap in the cylinders? Do I do this from the top or the bottom of the cylinders?
I think you check it at several points up and down the bore, haven't done it in a while. I recall the proper nominal end gap is about .003" - .004" of end gap PER INCH OF BORE DIAMETER.
I think service limit is actually about double nominal which sounds like a lot but there isn't that much compression loss at the end gap point, most of it is past the rings in the piston grooves.
  • DobbinsCMA
10 Jul 2014 12:52
#639617
That means I should be able to get 10 sheets of paper between the ends of my ring? Cuz it looks pretty small in my picture. 1 sheet a paper is 1 mil or .001 inches. What do you think about the gap?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • Dr. Gamma
  • Dr. Gamma's Avatar
10 Jul 2014 12:59
#639618
DobbinsCMA wrote: That means I should be able to get 10 sheets of paper between the ends of my ring? Cuz it looks pretty small in my picture. 1 sheet a paper is 1 mil or .001 inches. What do you think about the gap?
No, you go buy a set of feeler gauges.
10 pieces of paper, give me a break.
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: Nessism, peter1958
  • 4TheKZ1000
10 Jul 2014 13:07
#639620
go to AutoZone and spring $8 for feeler gauge........ :whistle:
  • DobbinsCMA
10 Jul 2014 13:10
#639622
Well I have this cool thing called a micrometer that measure to the ten thousandths place of an inch. I measured each page (thicker pages than normal paper) as being .01145 or .011. That being said, yes I would love some but why buy them for one use? Do you want to send me the money? Give me a break. Normally yes I would agree that the right tools matter when doing such important measurements. But thank you Dr Gamma for your reply.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • DobbinsCMA
10 Jul 2014 13:12
#639623
What I am asking is .0113 inches the right gap at .004 for these rings? Thats all.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • Dr. Gamma
10 Jul 2014 13:15
#639624
Stupid question for you Mr. Dobbins, what are you planning to use when you check your valve clearance??
That fancy micrometer??
The following user(s) said Thank You: peter1958
  • DobbinsCMA
10 Jul 2014 13:31
#639625
That is a good point. I guess I could but maybe I should get some. Though I do not appreciate your negative judgmental tone. This a place to help people not to be a jerk. Notice how 4TheKZ1000 said the same thing but not in a way that made him look like an condescending arse. I do not do this for a living nor do I pretend to be a professional so I understand that I may be a little ignorant.
Now back to my initial question of the gap for 72mm rings. Since you are so very experienced do you think you could give me a double check on my math? That would be most helpful Dr Gamma.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
10 Jul 2014 13:41 - 10 Jul 2014 13:48
#639628
Wiseco recommends setting the top ring gap using this formula-(bore size(in inches)) X .0040 Say your bore size is 80mm then 80/25.4(mm/in)=3.15 in. X.004= 0.012 in. end gap
www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
you would not want to use paper because you want to be able to "feel" the drag of the feeler gauges.
rings are either cast iron or chrome-moly,which are both much harder than paper and would be impossible to get the same "feel"twice .
hth,
Last edit: 10 Jul 2014 13:48 by 531blackbanshee.
The following user(s) said Thank You: PLUMMEN, DobbinsCMA
  • PLUMMEN
  • PLUMMEN's Avatar
10 Jul 2014 13:49
#639629
It also helps to make sure piston is sitting level/square in the bore when measuring.
Take a piston and shove it in upside down in the bore using it to square the ring up about midway down the bore, pull piston back out before measuring. :)
The following user(s) said Thank You: DobbinsCMA
