Gpz550 ignition advance more power!?
  • accubond
  • accubond's Avatar Topic Author
10 Jul 2014 09:19
#639570
Hi, now that my motor runs properly, is there a mod for tuning the igniton.
The ignition plate holes are not slotted so should I slot them and if yes what to do with timing.
Regards David
  • loudhvx
  • loudhvx's Avatar
Re: Gpz550 ignition advance more power!?
10 Jul 2014 11:08
#639590
First you have to verify where the timing is, and the advance curve. If it is the same as stock, then you have nothing more to do. The advance curve is in the manual. SO you will need a timing light and a really precise tach. The bike's tach is usually not precise enough if you really want it accurate.
With a Gpz motor, you do not want to go any more advance than stock. Stock motors will even get a little knocking on highway acceleration if you are not careful with the throttle and downshift when needed.
  • GPzEric
  • GPzEric's Avatar
12 Jul 2014 06:37
#639806
I remember a magazine story from the day where they took the timing plate out of an '81, found the right size die-grinder bit and made theirs adjustable, advanced the timing two degrees, and shimmed the needles .034", and they were rewarded with almost a whole horsepower on the dyno - 56hp - not much return for the work -
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
  • loudhvx
  • loudhvx's Avatar
12 Jul 2014 10:05
#639830
GPzEric wrote: I remember a magazine story from the day where they took the timing plate out of an '81, found the right size die-grinder bit and made theirs adjustable, advanced the timing two degrees, and shimmed the needles .034", and they were rewarded with almost a whole horsepower on the dyno - 56hp - not much return for the work -
...And at what cost on longevity... not worth it.
The later ZX550 motors do advance the ignition more at higher RPMs, but also have a more gradual curve initially (done electronically, not mechanically). It's that early advance, at the lower RPMs, that does the damage with the mechanical advance curves.
  • undiablo
  • undiablo's Avatar
12 Jul 2014 10:56
#639834
Is it possible do use a modern CDI zr750 ignition on old mechanical advance KZs?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • Nebr_Rex
  • Nebr_Rex's Avatar
12 Jul 2014 14:21
#639848
And that's why I recurved the timing on my 1000.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • loudhvx
  • loudhvx's Avatar
12 Jul 2014 15:20
#639861
The mechanical advance definitely is a compromise between ideal advance at higher RPMs, and saving the motor from knock at lower RPMs.
The analog electronic advanc is better,but likely is also a compromise. The best is probably digital advance, as in the more expensive Dyna products. The down side is that they cost a lot, and don't seem to be as reliable as the factory units.
The pickups for the later factory, analog-electronic-advance may fit into the KZ750 motors, but I'm not sure. I know on the KZ550's, it's close but does not fit without making some alterations to the case castings. (The KZ550, 650, and 750-fours used the same size pickups andtiming plates.)
Incidently, non of the above is actually CDI. They are all transistorized Kettering, AKA flyback, and sometimes referred to as simply "inductive".
