queations
  • koloj
  • koloj's Avatar Topic Author
queations
09 Jul 2014 18:31
#639495
First I have 1980 kz 750 four cylinder I'm currently rebuilding the block...but when im finished the to black hoses on the valve cover this can be blocked off or just a single hose to both ports won't hurt anything right cause its a bobber don't have that stuff no more....the other is I have a new tank but has no petcock so I have all four ports on the carbs closed or capped it will run right with it like this or is their a alternative for a bobber.....thanks
Re: queations
09 Jul 2014 18:38
#639497
"... I have a new tank but has no petcock..."
?? How will fuel get to the carbs? Ed
  • koloj
Re: queations
09 Jul 2014 19:25
#639508
It has a gas valve u turn on and off but no petcock meaning has only one connection some bikes have two one that is use as a vacuum like to part on the carb with when given thottle the enigine vac will draw gas in to the bowl faster....I got the motorcycle with all the carb ports capped...I just want make sure with all the ports capped the gravity is gonna feed the carbs enough fuel under heavy rpms and or load
Re: queations
09 Jul 2014 19:34
#639510
koloj wrote: ne vac will draIt has a gas valve u turn on and off but no petcock ...I got the motorcycle with all the carb ports capped....
Vacuum ports should be capped.
Vent ports should not be capped and should exit to open air.
Good Fortune! :)
  • koolaid_kid
  • koolaid_kid's Avatar
Re: queations
10 Jul 2014 06:45
#639549
The black hoses on the valve cover must be open to allow the engine to breathe. Consider connecting both to a T, then putting a small valve cover breather filter on it.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • koloj
Re: queations
10 Jul 2014 07:58
#639560
Okay thanks much
  • baldy110
  • baldy110's Avatar
Re: queations
10 Jul 2014 08:40
#639564
koolaid_kid wrote: The black hoses on the valve cover must be open to allow the engine to breathe. Consider connecting both to a T, then putting a small valve cover breather filter on it.
You do not have to keep those open, they are not the crankcase vents but part of the smog system.
The breather is on top of hte engine block behind the cam chain tesnioner. You can simply tie both ports on the valve covers together using a piece of hose.
  • pete greek1
  • pete greek1's Avatar
Re: queations
10 Jul 2014 10:25
#639576
What Baldy said,
Attachment DSCF1624.jpg not found
like this
Pete
  • koolaid_kid
Re: queations
10 Jul 2014 16:55
#639644
I stand corrected.
1983 GPz 750
