Performance mods KZ750G?
- oldryder
09 Jul 2014 08:50
presently resurrecting a 1980 750 twin. was wondering if performance parts like camshafts, stroker crank, or bore kits are still available and if yes, where.
thx in advance for help or suggestions.
ps. I know it'll never be a crotch rocket but I just like making it better.
- bountyhunter
Re: Performance mods KZ750G?
09 Jul 2014 11:48
never seen any performance parts for the 750 twin.
- koolaid_kid
09 Jul 2014 14:22There is a reason for that. The twins had a completely different goal from a 4 cylinder. If you want performance, get a 4 cylinder. If you want nice comfortable cruising, stick with the twin.bountyhunter wrote: never seen any performance parts for the 750 twin.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- slayer61
- KZR FLAG RELAY CARRIER #62
09 Jul 2014 14:56 - 09 Jul 2014 15:10koolaid_kid wrote:There is a reason for that. The twins had a completely different goal from a 4 cylinder. If you want performance, get a 4 cylinder. If you want nice comfortable cruising, stick with the twin.bountyhunter wrote: never seen any performance parts for the 750 twin.
Shell Thuet would have disagreed with this statement.
OK so it isn't a "common" motor for hot rodding, BUT, everything can be done. Check with megacycle for cam shafts. (475-20 and 475-40) Edco, in Petaluma can build a fantastic head and J&E make custom pistons for any application to YOUR specs in quantities of four or more. Carillo rods also do custom work. Good luck with your build. Paul
Last edit: 09 Jul 2014 15:10 by slayer61.
- bountyhunter
09 Jul 2014 20:42I didn't want to point that out and poop on the thread.....koolaid_kid wrote:There is a reason for that. The twins had a completely different goal from a 4 cylinder. If you want performance, get a 4 cylinder. If you want nice comfortable cruising, stick with the twin.bountyhunter wrote: never seen any performance parts for the 750 twin.
- bountyhunter
09 Jul 2014 20:46True, Anything's possible with a big enough hammer and a fat enough checkbook.slayer61 wrote:koolaid_kid wrote:There is a reason for that. The twins had a completely different goal from a 4 cylinder. If you want performance, get a 4 cylinder. If you want nice comfortable cruising, stick with the twin.bountyhunter wrote: never seen any performance parts for the 750 twin.
- koolaid_kid
10 Jul 2014 06:50So I'm a pooper, eh? :lol: :lol:bountyhunter wrote:I didn't want to point that out and poop on the thread.....koolaid_kid wrote:There is a reason for that. The twins had a completely different goal from a 4 cylinder. If you want performance, get a 4 cylinder. If you want nice comfortable cruising, stick with the twin.bountyhunter wrote: never seen any performance parts for the 750 twin.
Very true. Custom pistons, eh? I wonder what they would cost, since he will be making 4 pistons for a twin motorcycle.bountyhunter wrote:True, Anything's possible with a big enough hammer and a fat enough checkbook.slayer61 wrote:koolaid_kid wrote:There is a reason for that. The twins had a completely different goal from a 4 cylinder. If you want performance, get a 4 cylinder. If you want nice comfortable cruising, stick with the twin.bountyhunter wrote: never seen any performance parts for the 750 twin.
1983 GPz 750
- slayer61
10 Jul 2014 07:41koolaid_kid wrote:So I'm a pooper, eh? :lol: :lol:bountyhunter wrote:I didn't want to point that out and poop on the thread.....koolaid_kid wrote:There is a reason for that. The twins had a completely different goal from a 4 cylinder. If you want performance, get a 4 cylinder. If you want nice comfortable cruising, stick with the twin.bountyhunter wrote: never seen any performance parts for the 750 twin.
I recently had them make 4 pistons for a SR500 (ish :evil: ) motor. 1 in the motor and 3 on the shelf. About $120 per.
