piston rings
- koloj
piston rings
07 Jul 2014 11:19
I have 1980 KZ750 four cyclinder.....now the engine says 750ee so I'm wondering what rings I need and if any one has a good place or website to buy them....One more thing says set on lot of them does it mean for two pistons or Individual if someone has ordered them before...thanks for your time
- Mcdroid
- Gone Kwackers
Re: piston rings
07 Jul 2014 11:32
Get up on
www.kawasaki.com
and check the exact model number and year of your motorcycle for the correct part number...Kawasaki used different rings in different 750 models. At this time, the rings are still available from Kawasaki but are in limited numbers...you'll be buying a set for each piston. As they are still available form Kawasaki, any Kawasaki dealership will order them for you.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- BigFreakD
Re: piston rings
07 Jul 2014 12:31
At the bottom of your engine block on the left side (if your sitting on the bike) there should be a molding stamp that tells you the liters of the bike. For instance on one of my KZ's it says 0.999L. This tells me exactly what size the engine is. It should give you a very good idea of what size rings you need based on what engine that block belongs to.
Your best way is of course to pull your head and use some calipers on your cylinder wall to be exactly sure. For instance on the '82 KZ I have, it measures 73mm on the cylinder wall so I know I need 73mm rings.
Besides if you bought your bike used, there's always a chance the rings are no longer stock size. The block could have been bored. Best to check if you can do without the bike while you wait for the rings to come in.
Don't forget to hone!
Treat people with respect, until they prove they shouldn't be.
2007 Kawasaki 1600 Mean Streak (totaled)
2013 Yamaha FZ6R (Wife's current bike)
1981 KZ750 (Finishing up Cafe Racer)
1979 KZ1000J (Waiting on restore)
1982 KZ1000J (Being restored to sell)
- undiablo
Re: piston rings
07 Jul 2014 12:42
Well kz750 four has 66mm piston. From 1980 and 1981 bikes use piston rings part# 13008-5031 and piston 13001-1059 std size.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- undiablo
Re: piston rings
07 Jul 2014 12:51
1982 and up kz750s uses new piston and thinner rings 1.0-1.2-2.8mm
- koloj
Re: piston rings
07 Jul 2014 13:23
Another thing is I took block apart and rings look okay and gap in the cyclinder was within spec when I put it inch down I just had low commpression and I found I needed a valve job....only thing is I don't wanna buy them didn't need to or not buy them I needed them reason why I have buy gasket kit and don't wanna have to replace gaskets if I still have low commpression I was at 90 psi in all cylinders but valve were leaking with no camshafts
- BigFreakD
Re: piston rings
08 Jul 2014 12:27
If you're already in there getting a valve job done (which it sounds like you are) I'd replace those rings and hone too. It's not very expensive and might as well if you've already broken it down. Assuming it wasn't done recently.
