ZR750 Cylinderhed on KZ750E2
- DustDevil
07 Jul 2014 07:47
Hello Together,
since this is my first post here I want to introduce myself first.
My name is Udo and I'm currently in the middle of the restoration of my loved KZ750E. I own that bike since 17 years now, but during the last years I rode mainly other bikes and the KZ750 was "parked" in my garage for at least 7 years.
During her time in my hands the KZ already got some new parts like pistons, camshaft drive chain, valves,... but now I will build it up completely new as a kind of a cafe racer.
Now my problem:
The bearings of the camshaft of the original cylinder head don't look very well.
I still have a head of a Zephyr ZR750 in the shelve and thinking about mounting it...
Comparing the schematic drawings of the KZ750E2 head with the ZR750 head, I found out that the cylinder, pistons, camshaft, camshaft drive chain, chain guides, vales and the cylinder head gasket have exactly the same part numbers.
Only the head itself has a different part number and looks a bit different (ZR750 is more angled).
Since the engine is basically the same from KZ650 to the GPZ750 I assume that the ZR750 head will fit…
Has anybody experience with that constellation and knows if I still can use my Ceihin CV34 carbs from the KZ750E2?
Thanks in advance!
Udo
Now my problem:
Thanks in advance!
Udo
- azman857
Re: ZR750 Cylinderhed on KZ750E2
07 Jul 2014 11:01
As long as the cylinder spacing is the same, compression ratio isn't too high and the valves don't kiss the pistons, I'd say go for it.
- DustDevil
08 Jul 2014 02:41
Hi!
The spacing shouldn't be a problem, since the cylinder of both engines is exactly the same (same part number).
Unfortunately I have no possibility to measure the compression, but I just compared the part numbers of the connection rods and the crank shaft. It's also identically for both engines! Taking this into consideration I would assume that also the compression should not differ too much.
Has someone a clue about if the combustion volume of both heads is the same?
p.s.: Yesterday I started to assemble my old lady again : )
Attachment 20140706.jpg not found
