install electronic ignition 1979 ltd 1000
  • 1760emer
  • 1760emer's Avatar Topic Author
01 Jul 2014 14:20
#638600
I want to install an electronic ignition on my 1979 ltd 1000 I am not familiar with how to set the timing.
Rick
Emer
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: install electronic ignition 1979 ltd 1000
01 Jul 2014 17:00
#638614
If you are using stock ignition you don't need to set timing. If you are using a Dyna ignition you probably use the search feature and find your answer. By the way, welcome.
