do i need dual feed fuel valve
  • tomsbadkz
  • tomsbadkz's Avatar Topic Author
29 Jun 2014 16:21
#638384
im putting together a 1327kz motor with a LarryC worked GPZ head. im planning on running 38mm Mikuni carbs. Do I need a dual feed fuel valve or would a high flow single outlet like from Arlen Ness be enough. Any imput is appreciated. thanks
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • DFIGPZ
  • DFIGPZ's Avatar
Re: do i need dual feed fuel valve
29 Jun 2014 17:38
#638389
if the carbs have 2 inlets then dual if they have 1 inlet then single.
1984 750 Turbo
