timing chain tensioner
- jonarmstrong
28 Jun 2014 17:50
Just bought an APE timing chain tensioner off eBay. I didn't receive any information with it. Do I set it at a specific torque? If so, how much? I checked pin to pin measurement on my timing chain when I had the cover on and it was within spec but I'm getting a lot of noise that I have been told is abnormal. If I'm accounting for slack w the manual tensioner am I not losing timing between crank and cams? Thanks
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- 4TheKZ1000
Re: timing chain tensioner
28 Jun 2014 18:48 - 28 Jun 2014 18:52
here is how I adjust it.
with the tensioner out, I put a 17mm wrench on the timing advancer nut an turn it counter clockwise a 1/4 turn. This removes all tension off cam chain.
I put my finger in the tensioner hole and flip the tension idler bracket back and forth making sure all tension is off it
I then back off the tensioner stem so the APE tensioner can be installed freely without interference with the idler bracket.
I then lightly hand tighten the tensioner stem until the stem becomes tight, not to force it.
I then back the stem off 1 complete turn and lock it down. Your done!
Last edit: 28 Jun 2014 18:52 by 4TheKZ1000.
- jonarmstrong
28 Jun 2014 19:43
Counter clockwise?? Won't that pull the chain tight on the tensioner side? I'm just wondering. I would have thought clockwise to put all the slack at the back. Thanks for your help
- 4TheKZ1000
28 Jun 2014 20:11 - 28 Jun 2014 20:13
Try not to think GRASSHOPPER.
Try both ways, insert finger and repot back your findings.
Last edit: 28 Jun 2014 20:13 by 4TheKZ1000.
- jonarmstrong
28 Jun 2014 20:39
That's funny! I probably do think too much :blink: I'll report back in the morning. Thanks
- 4TheKZ1000
29 Jun 2014 09:51jonarmstrong wrote: That's funny! I probably do think too much :blink: I'll report back in the morning. Thanks
- jonarmstrong
29 Jun 2014 13:53
Ok, counter clockwise shoves the arm back toward the hole. Clockwise let's it go all the way in. But... The tensioner is evidently not for a kz. Oh well. Gotta go back on ebay
- DFIGPZ
29 Jun 2014 16:01
Back tensioner completely off install turn 17mm bolt in clock wise direction while doing this turn tensiner in BY HAND till you no longer turn it now stop back tensioner off 1 FLAT lock it down finished.
1984 750 Turbo
The following user(s) said Thank You: jonarmstrong
- ezrider714
29 Jun 2014 17:51
I vote clockwise also.....
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
Dyna Coils
