Rear sprocket/ Hub damper question
- CafeKid
28 Jun 2014 16:52
So i was told this this should not have this much play, do I need to replace the Rear hub damper?
s5.photobucket.com/user/MREMO/media/IMG_8137.mp4.html
Thanks!
Thanks!
'79 KZ400
Re: Rear sprocket/ Hub damper question
28 Jun 2014 17:04
Yes; you were told right. That looks really bad. Mine has zero play that can be detected by hand. The damper should keep the hub and wheel very snug and the only "play" should be that of the rubber damper compressing when accelerating or braking with the engine. Ed
The following user(s) said Thank You: CafeKid
- CafeKid
28 Jun 2014 17:10
Thanks Ed! Im gonna owe you a few beers by the time this bike is all put back together. :laugh:
'79 KZ400
