Did leak down my discovery
  • koloj
  • koloj's Avatar Topic Author
28 Jun 2014 15:30
#638304
So bought this bike 1980 kz 750h four cyclinder I lap the valves I guess not good enough getting air though few valves at 60 psi but that not the Strange part I hear air were the cam chain is...idk know if that normal and at tdc....what can be the cause and with the leak down should I hear any air.....also I took the jugs up and measured the rings in the cyclinder both for each piston the gap I mean they are with in spec they also look brand new to be honest....but little insight would be great been lot wrench hours
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Did leak down my discovery
28 Jun 2014 16:20
#638307
It could be leaking past the rings or it could be a head gasket not sealing causing it to come uo through cam chain galley.
