Engine number
- Markgrff17
Engine number
28 Jun 2014 04:02
hi again folks
before I post again would just like to say great forum, I have been looking through your posts and already found some great info.
now im looking for a little clarity on exactly what model engine I have ( im building my bike solely from parts sourced from mainly ebay!! )
the engine number is KZ550 AE 050705
thanks in advance mark
Re: Engine number
28 Jun 2014 06:07Markgrff17 wrote: ... the engine number is KZ550 AE 050705....
According to the information at Z1E
www.z1enterprises.com
KZ550 AE 050705 falls within the 1982 range of engine numbers.
KZ550-A3 1982
F:JKAKZFA1_CB500001~
E:KZ550AE035401~
KZ550-A4 1983
F:JKAKZFA1_DA012001~
E:KZ550AE055501~
The following user(s) said Thank You: Markgrff17
- Markgrff17
Re: Engine number
28 Jun 2014 06:41
thank you for the information.
just another question, looking at pictures of an 1982 A3 engine the tacho is mechanically driven. the engine I have has no provision for mechanically drive of the tacho and looks like it is fitted with a head from perhaps a 1982 H1 model. have you ever seen this parts interchange before?
cheers.... mark
cheers.... mark
Re: Engine number
28 Jun 2014 07:14
As Tom Jones says, it's not unusual to see engine heads being interchangeable between sister models such as same year CSR with mechanical tach and LTD with electronic tach.
Am thinking it would be be feasible to install an electronic tach to replace the stock mechanical tach.
- Markgrff17
Re: Engine number
28 Jun 2014 09:38
Thanks again
Would anyone know if the valves from an A3 and H1 are the same or are the H1 valves slightly bigger?
Many thanks. Mark
Many thanks. Mark
Re: Engine number
28 Jun 2014 13:47 - 28 Jun 2014 13:54Markgrff17 wrote: ...Would anyone know if the valves from an A3 and H1 are the same or are the H1 valves slightly bigger?....
Info on kawasaki.com includes parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
Last edit: 28 Jun 2014 13:54 by Patton.
Re: Engine number
28 Jun 2014 14:12
In this instance, the kawasaki.com search for KZ550-A3 (1982) "valves" will show:
EXHAUST VALVE Part No. 12005-1013 is used on the following:
Model (17):
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ550-D1 (GPz) (1981)
KZ550-F1 (Spectre) (1983)
KZ550-F2 (LTD Shaft) (1984)
KZ550-H1 (GPz) (1982)
KZ550-H2 (GPz) (1983)
KZ550-M1 (LTD Shaft) (1983)
ZR550-B1 (Zephyr) (1990)
ZR550-B2 (Zephyr) (1991)
ZR550-B3 (Zephyr) (1992)
ZR550-B4 (Zephyr) (1993)
ZX550-A1 (GPz) (1984)
ZX550-A2 (GPz) (1985)
ZX550-A3 (GPz) (1986)
INTAKE VALVE Part No. 12004-1016 is used on the following:
Model (17):
KZ550-A3 (1982)
KZ550-A4 (1983)
And will also show the parts as "Active," which means available at Kawasaki dealerships.
Many such "Active" parts are also available from Z1 Enterprises and other after market sources, sometimes at less expense.
Model (17):
KZ550-A3 (1982)
KZ550-A4 (1983)
Model (17):
KZ550-A3 (1982)
KZ550-A4 (1983)
- Markgrff17
Re: Engine number
28 Jun 2014 15:31
That's brilliant, thank you so much for the info. I'm watching some inlet valves on eBay at £15 each ( which sounds reasonable to me )
Fab forum!!!!!
Cheers. Mark
Fab forum!!!!!
Cheers. Mark
