Cylinder Stud Removal Tool?
  • Nessism
  • Nessism's Avatar Topic Author
27 Jun 2014 20:48 - 27 Jun 2014 20:49
#638210
750E2 Cylinder studs are giving me fits. Double nut trick ain't getting it done - stripped a couple nuts and afraid of damaging the threads on the studs. Can anyone recommend a good stud puller tool that won't break the bank? Was looking on Ebay for a Snap-On A50 but can't find one with the smaller rack appropriate for these studs.
Last edit: 27 Jun 2014 20:49 by Nessism.
Re: Cylinder Stud Removal Tool?
27 Jun 2014 20:55
#638214
:unsure: Tried heating the aluminum area with a torch just before the double-nut attempt?
May loosen the thread grip as the aluminum expands more than the steel.
Good Fortune! :)
  • Nessism
27 Jun 2014 21:02
#638221
Patton wrote: :unsure: Tried heating the aluminum area with a torch just before the double-nut attempt?
Good Fortune! :)
I heated the case and stud HOT. PB Blaster on both too.
Good reminder to go spray them again though. Can't hurt.
  • gwallis
  • gwallis's Avatar
28 Jun 2014 08:35
#638263
I recently broke the head off in the engine manifold. The screw was stripped beyond repair and I tired to use a pair of Vise Grips to remove the screw... only the head came off.
In talking to several people about using an 'EZ-Out' tool I was told that ...'If the vise Grips couldn't get it out the very small EZ-Out tool certainly would not. I opted to drill and Tap the hole.
I used a center punch to start a very small diameter drill bit... then a larger drill bit... until I was just short of the 6 mm hole size. I even left a little of the old screw in the threads. Using a T-Handled 6mm Tap the job was very easy... 2 turns in... 1 turn out...2 turns in... 1 turn out. Use WD-40 as cutting oil while tapping. Worked like a charm!
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
28 Jun 2014 09:10
#638268
Call APE
They make a tool that works very well for removing studs.
  • PLUMMEN
  • PLUMMEN's Avatar
28 Jun 2014 10:09
#638274
Check the local sears store for a stud remover. :)
  • turboking
  • turboking's Avatar
28 Jun 2014 12:21
#638283
Harbor Freight Item #69466 reg price $ 7.97........ :blink: on sale now for $ 2.97.
I've used a sear craftsman stud remover for years :dry: ....the HF remover looks to be the same :huh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • turboking
28 Jun 2014 12:24 - 28 Jun 2014 12:25
#638284
the HF tool removes studs up to 3/4 inch and has two holes :ohmy: .........one for large and one for small studs.......... :S
1985 GS 1150E
1983 GS 1100E
Last edit: 28 Jun 2014 12:25 by turboking.
  • Nessism
28 Jun 2014 13:08 - 28 Jun 2014 15:04
#638291
turboking wrote: the HF tool removes studs up to 3/4 inch and has two holes :ohmy: .........one for large and one for small studs.......... :S
Bought one a couple weeks ago, it's a POS. It doesn't bite into the stud, just turns around. Overpriced at $3.:(
Edit: Had another go with the HF stud remover. Installed it over the stud then grabbed the outside of the tool with channel locks to keep it from rotating while turning the tool drive. This allowed the teeth in the cam device to bite into the stud. Once I got the hang of it the tool worked okay, other than all the studs now have deep teeth grooves in them now. Hope that's okay. Saw that APE sells studs and nuts, but wasn't budgeting $150 for those. :S
Last edit: 28 Jun 2014 15:04 by Nessism.
