Kz550 valves
- Markgrff17
Kz550 valves
27 Jun 2014 12:43
Hi there
I'm new to your forum and looking for lots of advise. Firstly I'm pretty sure I need new valves both inlet and exhaust as I've measured their installed height and all are out of spec.
Where is the best place to purchase new ones from.
Many thanks. Mark
Many thanks. Mark
- Beaner242
Re: Kz550 valves
27 Jun 2014 13:03
Z1enterprises is pretty much the go to place our classic bikes. Bikebandit also carries a lot of parts. Good luck
1982 KZ1000K LTD Chopper
The following user(s) said Thank You: Markgrff17
- Markgrff17
- PLUMMEN
Re: Kz550 valves
27 Jun 2014 18:47
Have you checked to see if stems can be ground?
- Markgrff17
Re: Kz550 valves
28 Jun 2014 03:35
thanks for the reply
im sure a read in the Kawasaki manual that the valve length could not be adjusted but I will check it again.
cheers mark
cheers mark
