Hole blown through crankcase
  • vanmor
  • vanmor's Avatar
Re: Hole blown through crankcase
28 Jun 2014 00:29
#638236
New to the site and Kawasaki fours. Saying that, I've had experience with different types of engines.
This is really reaching, but if there were casting flaws in the engine cases, the excess pressure inside could have pushed those pieces out. I don't think that's what happened though.
When you have a failure like this, you almost have to disassemble the engine to find out what happened. Something turned loose inside the cases and blew those holes out. It doesn't always have to be a connecting rod or part of the rotating assembly.
You say the engine can be started and it runs with no noise right ? I'd say you lost a rod nut. The rod could still hang on with one nut left. The high RPM of these engines could have bounced the nut around several times. It would only take one rod nut to knock out the two places in your cases.
Your cases are toast. Those holes are too big to fill in with JB WELD. If you had the chunks that came out of the cases, you might be able to get away with it. You'll be better off scoring a used engine, cases, or another bike .
  • KZ Rat
  • KZ Rat's Avatar
28 Jun 2014 05:43
#638243
Wrong area for hydrolock damage-would be looking more for a chunk of metal/nut/bolt/part of the cam chain guide coming loose and exiting the case. Seeing that makes me remember getting the willies looking at a buddies z1rtc back in the day. Turbo under the seat spinning-say-25000 rpm-what could possibly happen if that thing grenades?
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
28 Jun 2014 06:39 - 02 Jul 2014 03:56
#638251
jumpship wrote: en.m.wikipedia.org/wiki/Hydrolock just what he mentioned. This is it 100%. The bike wouldn't turn over sometimes I wondered when attempting to start. So basically the new racing carbs and me leaving the bike on prime caused gas to go into the engine or just too much oil or both caused this
Hydrolock happens when the cylinder has fluid in it and when the piston rises it cannot compress the fluid so damage happens to the piston; rod; or head. The fact that your engine still runs ok indicates no damage was done to the rods, etc.; so it appears your engine did not suffer hydrolock. In any case, those holes in the front of the engine case would not have been caused by hydrolock.
I would pull the oil pan and see if there are any clues to be found there. You may find nuts, bolts, or chunks of this or that in there. Ed
Last edit: 02 Jul 2014 03:56 by 650ed.
  • Hemmek
  • Hemmek's Avatar
01 Jul 2014 12:25 - 01 Jul 2014 12:28
#638588
Hmm that's not overpreasure (think of how your crankcase would look if you tried to blow it up like a balloon, you would see bulging on every straight surface, and the weakest point would have blown, that area of the block is not a weak spot.
Hydrolock is almost unheard of in a aircooled street engine.
(besides those dumbasses who tries to use the engine as a submarine crossing rivers and such)ยจ
hydrolock occurs between the head and the piston.
most commonly it happens in nitro engines, (dragsters) because they pump so much fuel into the engine so it will only take a few cycles whitout combustion to bring the liquid content up to the point where it is no longer compressible.
btw your case is repairable but I would replace it since it will involves to much work IMHO.
Welding or soldering is the only way I see, and since it is so close to a sealing area it would require machining later.
no just get a new case.
But now you have peaked my interest, find out what caused this, take loads of pictures.
I put my money on a connecting rod bolt failure.
Now go out there and pull the pan take a good amount of pictures and the mystery will be solved.
Seriously if you had been living in Sweden and somewhat near here I would do it for you free of charge just because now I HAVE to know what happened ;) .
best regards H
Kawasaki kz750 E1 1980
Kawasaki GPZ 900R A1 1984
Last edit: 01 Jul 2014 12:28 by Hemmek.
The following user(s) said Thank You: roy-b-boy-b
  • harm
  • harm's Avatar
  • Tom
01 Jul 2014 18:15
#638621
I'm with KZ rat on this one. Something went through the cam chain/cam chain tensioner.
Let us know ASAP!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • jumpship
  • jumpship's Avatar Topic Author
01 Jul 2014 21:35
#638646
Alright guys, looks like all i need is some jb-weld!!!
[IMG
[IMG
im gonna humble myself, This was my first ever experience with a blown engine like this so A LOT was going through my head as you guys can see. Looks like the truth of the matter is :
1.Rod was bent first, and than the piston snapped off from the pressure, and the rod itself smashed its way through the case and the rod is now stuck against the crankshaft as seen in the picture. How the heck could this have happened? Engine had 20k miles on it....
I still dont know extactly what caused this, CR Special carbs too lean? Why would only one piston blow up and the rest look totally fine. I really think it was because left the fuel cock on PRIME and left it on its side stand and these kz's lean over way hard. So im thinking it was hydrolocking in that one piston and couldnt really fire and when i really got on the gas is when the rod firstly bent and then snapped the piston off.
Once again i'd like to mention that the bike at one point DID hydrolock when i left the fuel on the motor wouldnt turn, it was locked. i had to use some persuasion to start it and the very day i left work i left the fuel on again....................... www.zggtr.org/index.php?topic=1209.0 , and www.cbxworld.com/features/hydrolock/hydrolock.htm are both some sources that back up what im saying. Guys agree with me?
1981 KZ750-4
Rode GS's all this time and once i hoped on a KZ... well... hence the name!!
01 Jul 2014 22:55 - 01 Jul 2014 22:58
#638648
jumpship wrote: ...What narrows a lot of this down is that the bike starts and still runs strong. ....
jumpship wrote: ...She starts/runs on all 4 cylinders....
:huh:
Good Fortune! :)
Last edit: 01 Jul 2014 22:58 by Patton.
02 Jul 2014 03:50 - 02 Jul 2014 03:58
#638654
:huh:
Good Fortune! :)
+1 !
jumpship wrote:
"The bike fires right up with no abnormal clunking or anything, in fact it sounds exactly the same, firing on all 4 and sounds real strong and good actually, If the bike was running too lean and popped the engine i don't think it would still be able run like it is able to now..."
I find it remarkable that the engine still ran strong on all 4 cylinders and had no abnormal clunking or anything with a broken piston and a bent rod stuck against the crankcase. :blink: Ed
Last edit: 02 Jul 2014 03:58 by 650ed.
  • jumpship
02 Jul 2014 05:39 - 02 Jul 2014 08:27
#638657
I know man, I was in the moment and wasn't thinking straight... but there weren't any clunks because I think the rod was just spinning with the crankshaft and it already smashed through the case so there's nothing else to hit! Lol!! So how do u think this happened? I really don't want this to happen again when I build the engine back again
1981 KZ750-4
Last edit: 02 Jul 2014 08:27 by jumpship.
  • Nessism
  • Nessism's Avatar
  • Away
02 Jul 2014 06:02
#638658
Could be the previous hydrolocking episode bent the rod, which eventually caused the rod bearing to lock up and seize. Piston seizing from running too lean is not unheard of too. What does the other side of the piston look like?
  • KZ Rat
  • KZ Rat's Avatar
05 Jul 2014 08:18
#638952
Ouch! Time for a donor motor. Could be worse- could be the owner of this $20k piece of scrap metal!
Attachment m3004.jpg not found
Attachment m3002.jpg not found
Attachment m3001.jpg not found
  • jumpship
05 Jul 2014 08:20
#638953
The top of the piston is caked with carbon? And honestly it looks a little wet/damp around the edges... I have the 810 kit from a friend, now I heard milling the head increases compression but will I need to do anything if I shave the head or can I just throw everything back together the way it was
1981 KZ750-4
