Hole blown through crankcase
- Puffin
Re: Hole blown through crankcase
27 Jun 2014 10:54 - 27 Jun 2014 10:55
sounds more like you have thrown a Rod or someone shot your block :dry: if it was overfilled you would be surely pumping oil out through the breather
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
Last edit: 27 Jun 2014 10:55 by Puffin.
The following user(s) said Thank You: PLUMMEN
- Beaner242
27 Jun 2014 11:46
If you are going to try to repair it. I would recommend Quicksteel. same section as JB Weld. Stuff is hard as steel in about 15 minutes. Its a 2 part putty that you tear a piece off and knead it together. I had to use it on my gas tank and now carry a tube with me in my bag.
1982 KZ1000K LTD Chopper
- peter1958
27 Jun 2014 17:16
Might have been shot at. Newyork
www.kzzone.com/
- jumpship
27 Jun 2014 20:42 - 27 Jun 2014 20:44
Alright Boys, as promised.
**Not for the faint of heart*~Viewer Discretion Moment**~~ Put Children away~~*
Here She Is:
hmm anything critical in this area?? seems to only be the casing and the interal grooves and fins exterally that got punctured, guys think i can still get away with a weld? Someone please shed some light at first i am just trying to be tough about it, but in all honesty its KILLIN ME!!!!!
Key Points:
CR Special 29 MM Carbs tuned fairly well if you ask me i checked plugs in all kinds of ranges, but the last few times i rode she sputtered at high rpms, now inn the process of the sputter it sputtered one last loud time and thus is the result. But can a pair of carburetors lets say WORST CASE SCENARIO that its running LEAN as a son of a gun... i would think a piston would blow first!! Not a crankcase like this.
She starts/runs on all 4 cylinders which rules out timing, pistons, rings in my book.
AS someone mentioned i know i will have to pull the pan and inspect. I think honestly a rock or two maybe left over from construction on the road maybe??? 1/10000000 chance it slipped past and sort of behind the exhaust?
At this point i believe it was maybe an internal explosion... i mean WHATTTTTTTTTTTTTTTT the heck?!?!? Any drag racers out there ever seen anything like this? I guess its somewhat of a guessing game untill we pull the oil pan
Here She Is:
Key Points:
1981 KZ750-4
Rode GS's all this time and once i hoped on a KZ... well... hence the name!!
Last edit: 27 Jun 2014 20:44 by jumpship.
- Nebr_Rex
27 Jun 2014 20:47
What is compression on all 4 cylinders?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- jumpship
27 Jun 2014 20:56
ill test em all tommorow, but i aa got a question for you in the meantime, what the heck could have forced its way out of the case like that?
1981 KZ750-4
27 Jun 2014 20:59
I'm not sure what happened, but I am sure it had nothing to do with too much oil.
- KZ Rat
27 Jun 2014 21:09
F.O.D. caught in cam chain and slung out? (Assuming the cam chain is between 2&3 like the 1000). Can you see the cam chain /crank gear for the chain through the hole?
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
27 Jun 2014 21:25 - 27 Jun 2014 21:25KZ Rat wrote: F.O.D. ....
:lol: Betcha I'm not the only one who had to go hunting for that one. :lol:
en.wikipedia.org/wiki/Foreign_object_damage
Last edit: 27 Jun 2014 21:25 by Patton.
- KZ Rat
27 Jun 2014 21:36
- jumpship
27 Jun 2014 21:43 - 27 Jun 2014 21:58Looks similar to minee, doesnt seem like jb weld will do it this time for my bike :dry: lol i dont know why theres 2 holes in my case though still. well im gonna pull the pan and we'll see what wonderous things we will find... atleast it wasn't like this
Im thinking the bottom of the rod snapped off creating a Y shape and the Y shaped rod flew right into the crankcase wall and that rod is going to be sitting on top of the oil pan when i take it off. If i think about it now, theres no other explanation
1981 KZ750-4
Last edit: 27 Jun 2014 21:58 by jumpship.
- jumpship
27 Jun 2014 22:24 - 27 Jun 2014 22:27
en.m.wikipedia.org/wiki/Hydrolock
just what he mentioned. This is it 100%. The bike wouldn't turn over sometimes I wondered when attempting to start. So basically the new racing carbs and me leaving the bike on prime caused gas to go into the engine or just too much oil or both caused this
1981 KZ750-4
Last edit: 27 Jun 2014 22:27 by jumpship.
