KAwa Z1000H lots of white smoke
- z900750sei
26 Jun 2014 02:10
I'm rebuilding Z1000H. I have new piston rings, new gaskets, new valve stem seals. Valve stem, Cylinders and pistons are in tolerances. The biggest bore after honing is 70,07mm. Smallest piston is 69,931mm. Compression is from 12,2-12,9bar. I have a lot of white smoke and I burned 0,5L of oil in 80km. There is oil in pipes. Piston rings are bought on USA ebay and produced by HY piston rings.. I installed second ring with dot and notch pointing up. Is it possible that this ring should be pointing down because it looks like ring is pumping oil into head. Head is leak proof it is tested with gasoline. This is the same engine as on KZ1000G and pistons have mark KZT00H. I forgot to look direction of old second ring but mark N is on the same side as notch. If someone have same problem please help me.
regards Simon
regards Simon
Kawa Z1, Kawa Z1A, Kawa H1D 500, Rickman CR 900, Benelli 750 sei 1976, Kawa KZ 1300 1979, Kawa Z1000H fuel injection, Kawa Z1000J replica of ELR, Moto Martin KJ 1000, Kawa KE 175, Bimota Mantra 2001, Benelli tornado tre 900 2004, Kawa ZZR 1400 2008 and project Kawasta.
- moneypit
Re: KAwa Z1000H lots of white smoke
26 Jun 2014 14:23
Only thing I can think of is. Its possible that the oil ring is overlapped. Did the set you got have a corragated oil ring? If its overlapped it will burn oil.
Someone else should chime in with other maybe better advise. Good Luck
2-76 kz900
St Paul MN
St Paul MN
- turboking
26 Jun 2014 16:46
letter or dot go up for the rings........do your pistons have the expander and 2 wiper for oil rings.....or 1 piece oil ring..
possible laid over oil ring :huh: or broken compression rings :blink: ...or piston wrist pin circlip came loose :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- z900750sei
26 Jun 2014 23:42
I have three piece oil ring and everything looks O.K. I think ring can not overlapp if gap in piston is O.K.
