gaskets
  • jonarmstrong
  • jonarmstrong's Avatar Topic Author
gaskets
24 Jun 2014 17:37
#637899
Is there a gasket offered for between the top and bottom pieces of the case? All I'm finding are the sets and none of them have that particular gasket
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: gaskets
24 Jun 2014 17:49
#637901
jonarmstrong wrote: Is there a gasket offered for between the top and bottom pieces of the case? All I'm finding are the sets and none of them have that particular gasket
No such gasket exists
  • koolaid_kid
  • koolaid_kid's Avatar
Re: gaskets
24 Jun 2014 18:27
#637908
No, you use a sealant such as Yamabond instead.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
The following user(s) said Thank You: wireman, jonarmstrong
  • jonarmstrong
Re: gaskets
24 Jun 2014 18:40
#637910
I've seen several yamabonds available. Any particular one?
  • koolaid_kid
Re: gaskets
25 Jun 2014 07:32
#637950
Yes, you want yamabond 4 or Threebond 1104. Same stuff. Does not dry out or get hard.
1983 GPz 750
  • Tyler
  • Tyler's Avatar
Re: gaskets
25 Jun 2014 07:46
#637952
Hondabond 4, and Hondabond HT too, all the same stuff really. Never had a case leak with these sealants.
The trick with the 4 cylinder motors is make sure everything is ready to go, double check all the parts are where they need to be and have all your bolts clean and ready to go. Once that sealant is on the mating surfaces you need to get it together and torqued up in a limited window. That stuff does not dry hard but it does set up.
I was paranoid when I put my 650 cases together something would leak, 5 years later and no problems.
"74 Yamaha DT 400 Enduro
  • koolaid_kid
Re: gaskets
25 Jun 2014 11:22
#637968
Correct Tyler. Threebond makes all of it and repackages it for the various companies. Not sure why there is not a Kawabond. Bought my Yamabond at my local Kaw dealer before they crashed and burned.
1983 GPz 750
Re: gaskets
25 Jun 2014 11:55
#637969
Believe it of not, there is a Kawabond #5 (part #K61079-012A); no doubt it is made by ThreeBond. I've always used Hondabond just because it's available nearby. ThreeBond seems to have the market cornered. :laugh: Ed
www.gearhead.com/kawasaki-k61079-012a.ht...s/KUS//K61079-012A/1
Attachment 00005_2014-06-25.jpg not found
  • Nessism
  • Nessism's Avatar
Re: gaskets
26 Jun 2014 06:56
#638050
I use Threebond 1194 or the new version 1184. Z1 sells it. 1207B is another popular choice, as is 1211. All perfectly suitable.
